Interrupts — Parallax Forums
Interrupts
edgellmhedgellmh Posts: 85
edited 2008-06-10 19:44 in General Discussion
Is there a way to do interrupts with the javelin stamp as there is with the SX chip? I want to have a light blinking in the background while the main loop is doing things that take lots of time.
marshall edgell
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-06-10 14:42
    There are no interrupts but you can use PWM to generate a (square)wave signal
    in the background.
    If you select
    static int highTime = (short)57600;
    static·int lowTime = (short)57600;
    you should get a pulsing led (0.499968 sec off, 0.499968 sec on)
    static PWM led = new PWM(CPU.pin12,highTime,lowTime);
    Put a 470 ohm resistor in series with the led.
    regards peter
  • edgellmhedgellmh Posts: 85
    Clever.
    marshall
