How can you tell if a propeller chip is broken?
Hello,
I have 2 protoboards. The first one is detected correctly with prop tool. When I hook up the second (same com port, same prop plug, same 6V power supply) it says it scans the port but does not find any propeller chip. How to make a diagnostic for this board? The green led is on, is ther any diagnosis I can easily make with a multitester to find out if the chip is broken?
Paul Baker
