Touchscreen and Propeller?
I'm wondering if anyone has got a touchscreen working instead of a regular mouse. I've got a virtual keypad in the vga object and want to use a touchscreen to get the user input. seems like the ones at work are all USB inputs to the computer with software in windows xp for them. not sure if it will interface with the Prop without special drivers. any ideas?
You might have an easier time using a USB host like the Vinculum chip that's part of Parallax's USB Memory Stick Datalogger and several versions sold by FTDI as well. This has the capability of talking to USB HID devices like a touchscreen or mouse, but you'll have to do your own programming.
Post Edited (Mike Green) : 6/1/2008 12:37:26 AM GMT
welcome to the forum ! On my earlier job it was vice versa. All the touchscreens had a serial RS232-Interface.
But these monitors were all of a high-professional quality for industrial use (prices of 1200 up to 2000 dollars).
Did you ever made a productsearch on the internet for touchscreens with serial interfaces ?
best regards
Stefan
If rolling your own, what size? What kind of budget? I have some Gunze modules which put out RS232 in simple ascii x,y positions. I normally use these with 15" touch glass but believe they would work with other sizes just fine. However you would have to level shift back from the RS232 to suit the prop.
http://store.earthlcd.com/LCD-Products/Add-On-Touch-Screen-Kits
JMH
http://forums.parallax.com/showthread.php?p=713258
for how I used the 5-wire touchscreens from Digikey with a regular monitor to make a touchscreen that works with the PS/2 port of the proto board...
Thanks for the tip...
JMH
But take a peek at either MikroElectronica (or their US retailer Circuit Ed)... they have inexpensive·touch screen material, interface boards and complete assemblies.
http://www.mikroe.com/pdf/touch_screen_specification.pdf
http://www.circuit-ed.com/LCD-and-Adapters-C8.aspx
edit -
Guess you're looking for something larger, but I still think that most of these are going to be 4 wire resistive, in which case you can probably tear it open and go right to the touch material with an adc·if need be.· Just think of the plastic layers as two potentiometers...
Post Edited (Agent420) : 6/2/2008 3:46:09 PM GMT
Here's·the latest version of my driver.· Should be pretty straight-forward to use.· Let me know if you have any questions.
has a serial touch screen on the way ... http://www.4dsystems.com.au/prod.php?id=23
http://www.dontronics-shop.com/micro-oled.html
