Simple Serial and Using the data after
So Im am transmitting from one prop chip to another, specifically from a proto bored to a uProp.
The problem arises that I cant seem to get a useable number on the side of the uProp.
So here is what I am doing.
It is one wire setup with the Proto Board sending and the uProp receiving.
So for Sending its basically doing this.
And on the receive side ive got it looking for two things, Im trying to get 2 sets of 4 numbers each.
Im trying to use -1 and -2 as my identifier for which set of data is coming through.
Then I use number to convert it to a string.
Here is the issue. The value I get is strange. I get 00000000Number. Anyone know what I am doing wrong to get this error?
As always the help is greatly appreciated, and thank you for your time.
TJ
Ser.Tx(Number)
Repeat Data := Ser.Rx if Data == -1 Repeat r from 1 to 4 EGT[noparse][[/noparse]r] := Ser.Rx if data == -2 Repeat r from 1 to 4 CHT[noparse][[/noparse]r] := Ser.rx
Oled.PutText(0,0,0,0,255,255,255, Num.Dec(EGT)) 'Print the value to the screen
TJ
as your target is to display the numbers on a display. The numbers have to be translated anyway.
I would take the Extended Full Duplex Serial-object from the obex to realize the datatransmission.
obex.parallax.com/objects/31/
This objects has methods for sending decimal values as a "string" and methods to receive a string
receive a string like "5420" and transform it to the decimal VALUE 5420
and much more predefined ready for use.
It uses the FullDuplexSerial-object.
My Opinion about the simple_serial-object is:
it is simple CODED and has limitations in its use
that make it difficult to USE
The FullDuplexSerial-object is vice vera: it is complex CODED and easier to USE than simple-serial
The Extended FullDuplexSerial uses FullDuplexSerial and adds more methods to it
best regards
Stefan
Post Edited (StefanL38) : 5/27/2008 7:01:07 AM GMT
Thank you
TJ
Chip 1, TX Test Chip.
The·uProp reciving side.
This puts on the screen "2 :22 :2 :2 :22 :2 :"
and for the string size command 0000000014, I cant begin to explain why it has 8 zeros and then the lenght, Im assuming that its a 14 char string for some reason.
Diferent numbers being tranmsitted result in different strings being shown, but always the same length in the StrSize command.
For example 2 results in "N6NNNNNNN6NNNNN6"
and if I use this code with out the comma to end it.
I get "6666666666666" ·only 13·chars....
I have·tired both the Tx,Rx Str as well as Tx,·Rx Dec and then convert it·to a string.
At this point I'm so lost I dont know where I am anymore, So any help is always appreciated, and Thank you for your time to help.
TJ
Edit* The ser calls Extended_FDSerial.
Post Edited (TJHJ) : 5/27/2008 10:42:15 PM GMT
