Simple Serial and Using the data after — Parallax Forums
TJHJTJHJ Posts: 243
edited 2008-05-27 22:33 in Propeller 1
So Im am transmitting from one prop chip to another, specifically from a proto bored to a uProp.
The problem arises that I cant seem to get a useable number on the side of the uProp.
So here is what I am doing.
It is one wire setup with the Proto Board sending and the uProp receiving.
So for Sending its basically doing this.
Ser.Tx(Number)
And on the receive side ive got it looking for two things, Im trying to get 2 sets of 4 numbers each.
Im trying to use -1 and -2 as my identifier for which set of data is coming through.
Repeat
  Data := Ser.Rx
    if Data == -1
      Repeat r from 1 to 4
        EGT[noparse][[/noparse]r] := Ser.Rx
   if data == -2
        CHT[noparse][[/noparse]r] := Ser.rx
Then I use number to convert it to a string.
Oled.PutText(0,0,0,0,255,255,255, Num.Dec(EGT)) 'Print the value to the screen
Here is the issue. The value I get is strange. I get 00000000Number. Anyone know what I am doing wrong to get this error?
As always the help is greatly appreciated, and thank you for your time.
TJ
    edited 2008-05-27 05:01
    Data will never be -1 or -2. The Ser.Rx routine returns a value from 0 to 255 only. Other problems include that you're using subscripts for EGT and CHT with values from 1 to 4 while a 4 byte array has subscripts from 0 to 3.
    edited 2008-05-27 05:25
    Hello TJ,
    as your target is to display the numbers on a display. The numbers have to be translated anyway.
    I would take the Extended Full Duplex Serial-object from the obex to realize the datatransmission.
    obex.parallax.com/objects/31/
    This objects has methods for sending decimal values as a "string" and methods to receive a string
    receive a string like "5420" and transform it to the decimal VALUE 5420
    and much more predefined ready for use.
    It uses the FullDuplexSerial-object.
    My Opinion about the simple_serial-object is:
    it is simple CODED and has limitations in its use
    that make it difficult to USE
    The FullDuplexSerial-object is vice vera: it is complex CODED and easier to USE than simple-serial
    The Extended FullDuplexSerial uses FullDuplexSerial and adds more methods to it
    best regards
    Stefan
    Post Edited (StefanL38) : 5/27/2008 7:01:07 AM GMT
  • TJHJTJHJ Posts: 243
    edited 2008-05-27 19:27
    Awesome call on the extended serial object, but one question which mode should I use if I want it to be a one way one wire system? A little lost on this part.
    Thank you
    TJ
    ok now Im just pounding my head at a wall, Ive got to be missing something basic, so here it what Im doing, as always thanks for all the help.
    Chip 1, TX Test Chip.
    Pub Main
    ser.Start(9,8,2,9600)
    Temp := String("33")
    Repeat
    ser.str(String("6"))
    ser.str(String(","))
    The·uProp reciving side.
    PUB Gauge ''A display gauge and recoder
    DELAY.Init(8_000_000)
    OLED.InitOLED
    OLED.CLS
    Dira[noparse][[/noparse]18]~
    cognew(Getdata,@Stack1)
    REPEAT
     Print
    Pub Getdata
     ser.start(18,19,2,9600)
     Repeat
     Ser.rxstr(temp)
     display := temp
    Pub Print
     oled.PutText (4,0,1, 255,255,0,Display)
     oled.PutText (4,2,1, 255,255,0,num.dec(strsize(Display)))
     Delay.PauseSec(2)
     Oled.cls
    This puts on the screen "2 :22 :2 :2 :22 :2 :"
    and for the string size command 0000000014, I cant begin to explain why it has 8 zeros and then the lenght, Im assuming that its a 14 char string for some reason.
    Diferent numbers being tranmsitted result in different strings being shown, but always the same length in the StrSize command.
    For example 2 results in "N6NNNNNNN6NNNNN6"
    and if I use this code with out the comma to end it.
    Pub Main
    Repeat
    ser.str(String("2"))
    I get "6666666666666" ·only 13·chars....
    I have·tired both the Tx,Rx Str as well as Tx,·Rx Dec and then convert it·to a string.
    At this point I'm so lost I dont know where I am anymore, So any help is always appreciated, and Thank you for your time to help.
    TJ
    Edit* The ser calls Extended_FDSerial.
    Post Edited (TJHJ) : 5/27/2008 10:42:15 PM GMT
