Use the reset button? — Parallax Forums
HumanoidoHumanoido Posts: 5,770
edited 2008-05-21 23:07 in BASIC Stamp
Is it possible to have code see the reset button pressed
and go to another part of the code before the stamp resets?
I'm looking at the bs2px-24 with the attached schematic.
The code below won't work because reset is not on any of
the P0 throu P15 pins. It's on MCLR. I really need help with
this from one of the great stamp masters. (I'm developing
Penguin Pbasic code, do not want to add any keys, and
don't have other sensors to use because they are all being
used.)
humanoido
' {$STAMP BS2px}
' {$PBASIC 2.5}
Rst  PIN    1           ' note: needs MCLR pin, not 1
n    VAR   Word
n =  0
' when reset is pressed, pin MCLR goes low
DO
n = n +1
DEBUG DEC n
PAUSE 200
LOOP UNTIL (Rst = 0) ' wait until rst pressed
DEBUG "Rst was pressed"
STOP
    edited 2008-05-20 01:29
    A reset is just that. The processor is completely reset and the firmware starts over as if it were just powered up. There's no way for the SX processor to determine what caused the reset nor is there any way for the Basic program to get that information. Some other processors have a register with that sort of information, but the SX does not.
    edited 2008-05-20 02:24
    One thing you can do is count the number of times the reset button was pressed in rapid succession and base your actions on that. Here's some sample code:
    ResetCount VAR Nib
    'The following needs to be at the top of your executable code:
    READ 0, ResetCount
    WRITE 0, ResetCount + 1 MAX 15
    PAUSE 500
    WRITE 0, 0
    'This can come later...
    IF (ResetCount = 1) THEN
      'Execute code for two button presses.
    ELSEIF (ResetCount = 2) THEN
      'Execute code for three button presses.
    '... etc.
    ENDIF
    edited 2008-05-20 04:10
    I don't know if this will help you at all, but it is possible to feed a pulse (101) into MCLR via a capacitor, and also feed that pulse directly (no capacitor) into an input pin. The RESET occurs on the 1-0 transition through the capacitor, but the input pin can then detect if the reset button is still held down, and for how long, immediately after the reset. The time held down can be used to select different user run time options. That is the opposite of what you asked for, which was to do something _before_ the reset instead of _after_.
    I don't think the Penguin as is comes from Parallax has a capacitor on the RESET input, so that would be a hack. Many of the Parallax products do have a capacitor on the ATN input.
    The input pin might be the auxiliary input you have available on Penguin pin p5, or it might be possible to do some clever multiplexing with one of the other assigned pins.
    Tracy Allen
    www.emesystems.com
    edited 2008-05-20 10:03
    Thanks everyone for the fast responses and considerable
    thought put into each post and all the helpful information!
    Phil, I like the code idea and found some information about
    reset, but can you explain what's happening and offer some
    comments?
    Below is the test code. It works well and consistent. But one
    question. How can the code be modified to "not report one
    key press when first run?" I tried modifying it without luck.
    humanoido
    ' {$STAMP BS2px}
    ' {$PBASIC 2.5}
    ' Use the reset button and count the number of times pressed
    ResetCount VAR Nib
    ' BASIC Stamp Syntax and Reference Manual 2.2 • www.parallax.com • Page 129
    ' When the BASIC Stamp module is reset, all RAM variables including DIRS
    ' and OUTS are cleared to zero. This affects both main and auxiliary I/O
    ' pins. On the BS2p24, BS2PE, AND BS2PX, the auxiliary I/O pins from the
    ' interpreter chip are not connected to physical I/O pins on the BASIC
    ' Stamp module. While not connected to anything, these pins do have
    ' internal pull-up resistors activated, effectively connecting them to Vdd.
    ' After reset, reading the auxiliary I/O from a BS2p24, BS2pe24, OR BS2px24
    ' will return all 1s.
    ' ---------------------- Main program -------------------------------
    ' The following needs to be at the top of code:
    DEBUG "Start",CR
    READ  0, ResetCount
    PAUSE 500
    WRITE 0, 0
    ' ---------------------- Main Routine -------------------------------
    IF (ResetCount = 0) THEN
    DEBUG "1 button press",CR   ' Execute code for one button press
    ELSEIF (ResetCount = 1) THEN
    DEBUG "2 button presses",CR ' Execute code for two button presses
    DEBUG "3 button presses",CR ' Execute code for three button presses
    ELSEIF (ResetCount = 3) THEN
    DEBUG "4 button presses",CR ' Execute code for four button presses
    ELSEIF (ResetCount = 4) THEN
    DEBUG "5 button presses",CR ' Execute code for five button presses
    ELSEIF (ResetCount = 5) THEN
    DEBUG "6 button presses",CR ' Execute code for six button presses
    ENDIF
    STOP
    edited 2008-05-20 17:20
    No, there is no way to distinguish between a power-on reset and a single button push. The code works as follows:
    1. When reset, the reset count is read from EEPROM, incremented, then written back.
    2. As long as resets keep occurring within 500ms of each other, this number keeps getting incremented until it reaches 15.
    3. If more than 500ms transpires after the last reset, the count in EEPROM is set to zero for the next round of resets.
    4. The last value read from memory is the reset count, minus 1.
    Thanks Phil Pilgrim (PhiPi), the description is very helpful! That's
    interesting, with the reset button showing any single reset as a single
    keypress (button pressed or not) - As Mike Green pointed out, a
    reset is just that. It's remarkable code, as through software there
    are 15 functions that can be gained through pressing this one reset
    switch. That solves my original challenge and I thank you very much
    for your help. I have this working in new code and will post the entire
    application when completed so everyone can benefit from it.
    Tracy Allen, thank you for the hardware technique which is a very
    good idea for some great Penguin Robot hacking. There's no capacitor
    on Penguin's RST input line but there is one on BOE. Any idea why the
    inclusion and exclusion? Attached is a comparison of the reset circuit
    schematics of BOE and Penguin, side by side. For reference, the BOE
    shown is rev. C.
    humanoido
    492 x 309 - 75K
