IRL 520 MOSFET Switch
I'm planning to use the attached circuitto swith a 12VDC fan on/off by switching the IRL520 MOSFET on and off.
In the final circuit, I will use a DS1620 to bias the IRL520 on and off.
With just the circuit shown in the attachment, how do I test its operation? Do I simply short the Gate to either +12VDC or GND (which rail turns it on and which turns it off) or do I have to use a resistor of a speciifc value in series with the Gate, and then connect to a rail?
Thought I would check before I try something and smoke it.
Thanks.
Thanks.
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
