New User Questions — Parallax Forums
New User Questions
JohnPJohnP Posts: 15
edited 2008-05-15 19:11 in Propeller 1
Just getting started with Propeller on the Demo board and have a couple
of questions:
1. The very first demo program, Output.spin, works fine, for
pins 16 or 17. Changing the pin number to 18, for instance,
causes to LEDs to blink. Explanation ?
2. Does anyone have timing information for the math functions,
i.e. number of cycles, just roughly.
John-
  • JohnPJohnP Posts: 15
    edited 2008-05-14 18:39
    Sorry, I solved the first question - you know how
    it is with new users (enthusiastic but clueless).
    John-
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2008-05-14 23:23
    Which math functions, assembler or spin? The number of cycles for all the assembler instructions are in the data sheet and manual (all 4 cycles). The spin instructions are around 40 to 100 times slower. If you want to find out do something like this
    PUB test(num1,num2):temp1,temp2,temp3
      temp1:=cnt
      temp3:=num1+num2
      temp2:=cnt
      return temp2-temp1
    Something to be careful of is that this will take different amounts of time depending on where the variables are.
    edited 2008-05-15 01:17
    Thanks for the reply.
    I saw the assembler cycles; should have mentioned
    I was curious about the Spin cycles.
    I have tested in the way you suggest in other languages, however,
    I'm just getting started with Spin and I'm not an adept programmer
    in any language.
    John-
    edited 2008-05-15 02:22
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-05-15 17:12
    speaking of spin cycles....has anyone made a propeller based washing machine?
  • tpw_mantpw_man Posts: 276
    edited 2008-05-15 18:27
    @Ken Peterson
    LOL, but I do not think so.
    I am 1011, so be surprised!
    Advertisement sponsored by dfletch:
    Come and join us on the Propeller IRC channel for fast and easy help!
    Channel: #propeller
    Server: irc.freenode.net or freenode.net
    If you don't want to bother installing an IRC client, use Mibbit. www.mibbit.com
    Ken Peterson said...
    Oh no! I'm not going there.. Then I've have one more task to do before I can play with the Propeller. [noparse]:)[/noparse] [noparse]:)[/noparse]
    OBC
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook 1.4
    Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
    Got an SD card? - PropDOS
    Need a part? Got spare electronics? - The Electronics Exchange
