Reinforced jumper wires for breadboarding
I've never splurged much on breadboarding gear, especially wiring.· A spool of 22awg solid core and some wire strippers serve just fine 99% of the time.
But recently while placing an order at Elexp, I decided to srping for some reinforced jumper wires - specifically male to female and male to male sets.· They were just a couple of bucks.· I'm sure other places carry them as well.
I've never used them, but these things make life so much easier when dealing with pinned connections for which you have no sockets.· like individual pins in a serial or vga cable to a breadboard.· Or any mini board that has pins you need to connect.
http://www.elexp.com/bb_0mf1.htm
Along those lines, I ordered some male and female pins to make additional sets with my own wire.
The std male to male pin wires are great for connections that may require moving around the board, becuase the machine pin ends don't bend or break like regular solid core wire sometimes does.
http://www.elexp.com/bb_jw90.htm
I don't know how I've lived without them [noparse];)[/noparse]
Post Edited (Agent420) : 5/5/2008 6:36:17 PM GMT
I decided to splurge one time and order some from SparkFun. I love them and ordered more. I have also found them at Jameco, and I actually prefer the Jameco wires to the wire found at SparkFun.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
~~ dRu ~~
http://www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/800-00029/List/1/ProductID/403/Default.aspx?SortField=ProductName%2cProductName
