Boe Bot CMUcam
I have recently purchased one of the cams and have not been able to get it working with the code that is supplied on the CD you get with the cam and also with the code that is posted on the product information webpage. Specifically using function three of the demo code. I cannot get it track a color like the Boe Bot on the video. It works only for a second and then stops. I have tried changing the 'Pause' commands in the code but haven't been successful. Does anyone know how to get the cam to operate correctly? Thanks in advance. Phillip
- Stephen
- Stephen
to the code I have running on my CMUcam
and Boebot. This code runs perfect and does
not need modifications. Which CMUcam version
do you have? The appmod version with or
without the ribbon cable? You may
need to check the seating on the connector
and boards, verify the jumpers and correct
install, replace the BoeBot batteries, reload in the
code, and try again. One other thing to check - the
plug in connector for the ribbon cable has 2 rows -
only one row will work.
humanoido
It’s not that the code on our website is incorrect…For the vast majority of CMUCam customers it probably works fine. There were apparently some changes made to recent versions which we were not informed of and which the old code does not work. Of course, code is supplied on CD so there should not be an issue. We may have to find a way to list both programs.
Chris Savage
Parallax Tech Support
CMUcam1 V2.3 with the ribbon cable.
www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/cmu/List/1/ProductID/29/Default.aspx?SortField=ProductName%2cProductName
Most of these programs are not found on the supplied
CMUcam CD. (CMUcam1 AppMod Ver B CD)
So it could be an issue because those codes are
very useful, for example, functions where the LED menu
is not needed, and the ability to find and push a soccer ball!
I never heard back from Seattle Robotics, maybe
they're very busy, but a diagram is still needed showing
exact PINS USED to the appmod board and FROM the
appmod board, and the red camera
board for CMUcam1 version V2.3. Anyone have this?
It's very unusual not to include pin information in the manual
so I think Parallax had little or no involvement in the printing
of the User Guide version 1.0.
One question about the CMUcam code as there are no comments
to explain - what is the difference between turn left &
rotate left, and turn right & rotate right? What is the thinking
in terms of turning directions and angles and the use
and reason for each? (see posted code). Thanks very much
in advance.
humanoido
Phillip
- Stephen
