Boe Bot CMUcam — Parallax Forums
Boe Bot CMUcam
PhillipPhillip Posts: 9
edited 2008-04-24 23:39 in Robotics
I have recently purchased one of the cams and have not been able to get it working with the code that is supplied on the CD you get with the cam and also with the code that is posted on the product information webpage. Specifically using function three of the demo code. I cannot get it track a color like the Boe Bot on the video. It works only for a second and then stops. I have tried changing the 'Pause' commands in the code but haven't been successful. Does anyone know how to get the cam to operate correctly? Thanks in advance. Phillip
    edited 2008-04-16 03:59
    Could you ATTACH your code to your next post so we could take a look?
    - Stephen
    edited 2008-04-16 04:05
    Also, you might describe how you are powering the BoeBot with the CMUcam and double check your connections.
  • PhillipPhillip Posts: 9
    edited 2008-04-16 19:56
    Here is the sample code that is supplied on the CD that comes with the cam. The cam poowers up with out any problems because we can run functions one and two but once we get to function there, the cam stops working. Thanks. Phillip
    edited 2008-04-16 20:43
    Forgot to mention where in the code I am trying to get working. The part of the code is labeled "Follow and Track Color" It then has an IF/THEN statement about function 3.
    edited 2008-04-18 02:05
    Sorry, don't see "Follow and Track Color" in the program.
    - Stephen
    edited 2008-04-19 15:12
    I checked your posted code, and it's identical
    to the code I have running on my CMUcam
    and Boebot. This code runs perfect and does
    not need modifications. Which CMUcam version
    do you have? The appmod version with or
    without the ribbon cable? You may
    need to check the seating on the connector
    and boards, verify the jumpers and correct
    install, replace the BoeBot batteries, reload in the
    code, and try again. One other thing to check - the
    plug in connector for the ribbon cable has 2 rows -
    only one row will work.
    humanoido
    edited 2008-04-21 02:42
    Thanks for the replies. I have spoken with the maker of the CMUcam (Seattle Robotics) and also to the person who wrote the code for the CMUcam and long story short, my CMUcam had a problem. Parallax sent me another CMUcam and said that they would check to make sure it worked with the code on the included CD before they sent it. I haven't had time to check the new CMUcam but will tomorrow.·So hopefully the problem is·solved.·Also found out from Parallax that the code that is supplied on the product information webpage for the CMUcam is not correct.
    edited 2008-04-21 15:15
    Phillip,
    It’s not that the code on our website is incorrect…For the vast majority of CMUCam customers it probably works fine. There were apparently some changes made to recent versions which we were not informed of and which the old code does not work. Of course, code is supplied on CD so there should not be an issue. We may have to find a way to list both programs.
    edited 2008-04-22 17:34
    The Parallax posted code is not working on
    CMUcam1 V2.3 with the ribbon cable.
    www.parallax.com/Store/Microcontrollers/BASICStampModules/tabid/134/txtSearch/cmu/List/1/ProductID/29/Default.aspx?SortField=ProductName%2cProductName
    Most of these programs are not found on the supplied
    CMUcam CD. (CMUcam1 AppMod Ver B CD)
    So it could be an issue because those codes are
    very useful, for example, functions where the LED menu
    is not needed, and the ability to find and push a soccer ball!
    I never heard back from Seattle Robotics, maybe
    they're very busy, but a diagram is still needed showing
    exact PINS USED to the appmod board and FROM the
    appmod board, and the red camera
    board for CMUcam1 version V2.3. Anyone have this?
    It's very unusual not to include pin information in the manual
    so I think Parallax had little or no involvement in the printing
    of the User Guide version 1.0.
    One question about the CMUcam code as there are no comments
    to explain - what is the difference between turn left &
    rotate left, and turn right & rotate right? What is the thinking
    in terms of turning directions and angles and the use
    and reason for each? (see posted code). Thanks very much
    in advance.
    humanoido
    edited 2008-04-24 01:02
    Well the problem continues... The new CMUCam came in and seems to be working correctly. However, when both servos that control the wheels are plugged in to the correct servo ports on the board, the program doesn't know what to do. When only one servo is plugged in, the program works correctly but sense only one wheel is working the Boe-Bot goes in a circle. As soon as the second wheel servo is plugged in, the program shuts down almost instantly. It seems that there is some kind of electrical short but I have tried the CMUCam in several other boards with several other servos and the same problem. Anyone know what is wrong? Thanks.
    Phillip
    edited 2008-04-24 01:07
    Make sure you have enough power and you are not trying to use the stamps or stamp boards regulator for all the parts.
    - Stephen
    edited 2008-04-24 02:16
    The only thing that is attached to the board is the two wheel servos and the cam. Right now while I am trying to get the Boe-Bot working I am using the AC adapter so there should be enough power being supplied.
    edited 2008-04-24 03:49
    If you are running the servos off the 5V output of the board's regulator, you may be overloading the regulator. Servos can draw up to 1Amp each when they're starting or under heavy load. If your AC adapter puts out more than 7V or so, you can't run the servos off it directly. You might need a separate AC adapter that puts out 6V and use that for just the servos. You could run the servos and the BoeBot off the 6V adapter if it has enough capacity (2.5A peak).
    Thanks for the reply Mike. I haven't had time yet to see if the AC adapter is the problem or not but hopefully I will soon.
