Long distance comunication
Hello,
I am working on an ever expanding robot and I would like to add wireless control to it. By this I mean I would like it to be able to communicate between the robot and my computer. I need it to be a wireless connection, but I require it to be able to have a range of 3 kilometers (1.8 miles). Does anyone have any suggestions or ideas as to how I can achieve this?
That said, there are some WiFi systems with that sort of range like:
radiolabs.com/products/wireless/antennas/2.4gig/long-range-wifi-kit.php. Do a web search for "long range wifi".
Other options include getting an amateur radio license, then using a 2M walkie-talkie with a packet modem at each end.
Another possibility would be to get a cell phone/modem designed to be used with an external controller and using the cell modem for communications. SparkFun has some modules and breakout boards: www.sparkfun.com/commerce/categories.php?cPath=66_69.
Want to share why you need such a long range?
In the applications I've done, we were transmitting two-way data at 9600 and below. With reasonable line of sight, the 100 mW can work at a couple of miles, the 1 watt can get out there 5 - 7 miles. Special antennas can increase that to 30 - 40 miles but the antennas are very directional.
Mouser, Digikey, B&B Electronics all sell them. As Mike pointed out, they are more expensive than a piece of wire. You'll be looking at about $300 - $400 per transciever by the time you get an antenna and cables.
Cheers,
Tom Sisk
http://www.siskconsult.com
As far as the cell phone module goes, can some one explain that to me please? I don't really understand how it works, what it is, or how i would be able to interface with a basic stamp.
Depending on obstructions, repeater access, antennas and radio setup this distance may or may not be a problem.
