Controlling source voltage with a BS1 — Parallax Forums
GarthGarth Posts: 18
edited 2008-04-22 12:36 in BASIC Stamp
Ok, I'm still new at this. I need to send source voltage to my load. I've got it working (see schematic) but I can't help thinking there is a more efficient way to accomplish this.
Any ideas and comments are welcome.
    edited 2008-04-20 21:00
    The very simplest thing would be a 5-volt reed relay like Radio Shack 275-232. It will draw 20 mA (the permissible max from one pin) and switch isolated SPST contacts. Just wire it from any pin to ground and put a reverse diode across it, and you're in business.
  • GarthGarth Posts: 18
    edited 2008-04-20 21:29
    Thanks for the response Erco. I had considered a relay however, i should have mentioned that I need to repeat the circuit 5 time and I also need to keep the foot print as small as possible.
    Thanks again
    edited 2008-04-21 00:26
    If you're sold on transistor switching, you can probably use a single transistor. Try eliminating your 3904 transistor and reduce your 100K bias transistor down to 330-1000 ohms to switch your 3906 on. TIP31 is a good power transistor with heat sink if you're pulling molto current.
    edited 2008-04-21 03:05
    Garth,
    Since your voltage supplies are different, using a single PNP transistor won’t work.· You need the NPN in this case as a high-side driver.
    If you can move your load so that it is happy with one side connected to your 24V supply, then a single NPN transistor solution will work.
    BTW) In your schematic, it looks as though the Collector and Emitter of the PNP are swapped.
    What are the current requirements of your load?·
    That will help determine the correct transistor and resistor values at the transistor base that·you should use.
    Beau Schwabe
    IC Layout Engineer
  • BartyBarty Posts: 2
    edited 2008-04-21 03:20
    Take a look at ULN2803A - Its a great chip for doing this type of thing. 8 independent channels that hardly no power from the BS to drive it...
    The chip itself doesn't even a power pin on it (Only a single ground)...
    Wire your load directly to the 24Vdc supply and use this device to control the connection to ground...
    As mentioned mentioned, if the load is inductive (like a motor or relay), place a diode across the coil to reduce the "fly back" energy...
    Happy Stamping....
  • David H.David H. Posts: 78
    edited 2008-04-21 13:33
    Garth,
    Also make sure your positive power is connected to VDD and your ground connected to VSS.
    Good luck with the project.
    David
    There are 10 types of people in this world,...
    Those that understand binary numbers, and those that don't!!!
    edited 2008-04-21 23:16
    Barty said...
    Take a look at ULN2803A ... As mentioned, if the load is inductive (like a motor or relay), place a diode across the coil to reduce the "fly back" energy...
    Actually, the ULN2803 has the protective diodes built in and·pin 10 should go to +V.· [noparse][[/noparse]Though often mistake for one, Pin 10 is not·a power pin.]
    Note -- These "gates" (having "open collector" outputs) are for sinking current, not sourcing voltage.
    Post Edited (PJ Allen) : 4/21/2008 11:21:58 PM GMT
  • kingspudkingspud Posts: 128
    edited 2008-04-22 00:09
    Just a heads up!
    There is a great chip out there by the name:
    UDN2981
    http://www.datasheetcatalog.com/datasheets_pdf/U/D/N/2/UDN2981.shtml
    It is an 8-channel source driver chip.
    You have 8 input points that can you put 5 volts into and then you can put 15 volts into the 2981, which in turn drive 15 volts out of each 8 outputs.
    Check it out, it might work for you,
    Joe
    “Intellectual growth should commence at birth and cease only at death”
    Albert Einstein
    edited 2008-04-22 00:36
    WHERE HAS THIS CHIP BEEN ALL OF MY LIFE - I could have used this years ago!
    Thanks kingspud!
    Great matching/pairing device to the 2803...
