Penguin IR DETECTOR relocation Question? — Parallax Forums
ZaxZax Posts: 48
edited 2008-04-23 09:25 in Robotics
I am trying to Place the IR DETECTOR ON PIN 5
This should give much better reception for Humanoidos penguin_wireless_soccer.bpx When trying to Control it from behind.
(See Pics for Location of IR DETECTOR) But for some reason I do not know, the Penguin does not want it there, and will power up but then the power on led Does not come on and it will not run! Any help to resolve this would be very welcome!!
Thanks Rick
    edited 2008-04-17 16:24
    Try removing the second IR emitter from the expansion
    socket and see if Penguin operates normally. If it does,
    check the IR emitter with a meter and see if it's shorted.
    This is the likely cause. A short would put +5 volts DC
    from the center pin directly to ground on the outer pin
    and cause the failure that you see.
    humanoido
  • ZootZoot Posts: 2,227
    edited 2008-04-17 20:36
    Did you solder the second detector piggy back on the first one, but flipped around? It *seems* that way from the pic. If so, then the second one is miswired and you may be shorting out through the phototransistor in the detector, as humanoido suggests.
  • ZaxZax Posts: 48
    edited 2008-04-18 14:29
    No I just Plugged it in where the free slot is on Pin 5 is for the Ping On The board in J3
    edited 2008-04-19 07:22
    I ran this experiment on my nickel Penguin Robot
    and placed a new IR detector into the expansion
    slot, with the bubble facing in the forward direction.
    It works fine. Zax, it seems the detector you used
    is shorted.
    It's a very good idea to relocate the detector
    to this position as the pins can be bent slightly
    to calibrate the position.
    You will notice, the humanoid Robonova-1 has this
    IR detector configuration on the top of the head,
    facing upwards, and the remote works well from
    all directions.
    It would be interesting to replace the original
    detector on Penguin Robot with another socket,
    and keep a new detector in one, with its longer
    pins for adjustment. For other projects, the
    detector could be removed easily, and the
    two expansion sockets would provide 2 ports.
    Also, a PING))) could be forward mounted,
    leaving room for the IR detector, above and
    behind.
    humanoido
  • ZaxZax Posts: 48
    edited 2008-04-19 19:20
    Thanks humanoido!!
    For checking it for me, I to have Placed not 1 but 6 new IR detector into the expansion
    slot, with the bubble facing forward And still get the same results, it powers on for a sec and Dies!
    When I place the Ping))) in its fine my Ir detectors work fine when I try them in my other bots
    Seems I am getting a lot of Penguin rebellion lately!!
    her is another ? to chang the location in you soccer Program is this all I need to do??
    Declarations
    time VAR Word ' IR remote timing word
    remoteCode VAR Byte ' IR remote code byte
    T4Const CON 2800 ' IR remote constants
    TConst CON 1400 ' IR remote timing constant
    IR CON 5 ' IR remote, IR is on pin 4 I WAN'T IT ON 5 "I is this right humanoido?"
    Thanks Rick
    edited 2008-04-20 02:02
    In reference to the program: penguin_wireless_soccer.bpx
    http://forums.parallax.com/showthread.php?p=675655
    To relocate one infrared receiver from pin 4 to pin 5
    Replace this code, found in the Declarations:
    IR CON 4 ' IR remote, IR is on pin 4
    With this code:
    IR CON 5 ' IR remote, IR is on pin 5
    Add a comment stating you modified the code for moving the IR receiver
    from pin 4 to the expansion slot pin 5 .
    Then save the modified code with a new name such as:
    penguin_wireless_soccer_zaxmod1.bpx
    humanoido
    Post Edited (humanoido) : 4/20/2008 2:18:11 AM GMT
    edited 2008-04-20 02:12
    You tested 6 ir sensors, one at a time, in the
    expansion slot, and Penguin will power on for
    a second and die. Correct?
    When this happens, what is the status of the
    small blue LED? Does it fade out gradually
    or abruptly go off? Does it look dimmer than
    normal at power on with the IR removed?
    Did you try new batteries? You may want
    to do some testing with a meter.
    humanoido
    Post Edited (humanoido) : 4/20/2008 2:17:23 AM GMT
  • ZaxZax Posts: 48
    edited 2008-04-20 03:27
    Yes Humanoido, 1 at a time I even went as far as to power on before pluging them in, and when I do the light goes out Fast!!! Yes it abruptly goes off. As I mentioned before the ping works fine! and the IR Detectors wer all tested in my sumo bots and worked fine! And any time my bots malfunction I try a new power scorce so that wasnt it And unfortunitley I dont have a meter LOL!
    Thanks for your time and help Humanoido, Where do I send the Check???Iit feels like I'm your full time job!
    Thanks a bunch!!!
    Rick
    edited 2008-04-20 15:20
    With no meter or scope, with power off, try pulling the board,
    and running it in the configuration shown in the manual on
    page 6 for centering the servos, only unplug the servos.
    Unplug the ribbon cable and plug in back in. Do a
    complete visual inspection of the motherboard for
    anything unusual. Put in one IR receiver into the
    expansion slot and power on, then see what happens.
    It the same problem persists, it's recommended that you
    use the Parallax IR emitters that come with the BoeBot kit.
    What other bots do you have, and what is the make, brand,
    and part number of the IR receiver that you're using?
    Hey, you're welcome, and it's a pleasure to help, and
    thank you for the wonderful learning experience.
    humanoido
  • ZaxZax Posts: 48
    edited 2008-04-21 13:59
    Hello again Humanoido,
    I am using the Parallax boe bot ir detectors.
    I tried all that you suggested and still have the same trouble.
    I have 2 boe bots, 2 sumo bots,, 1 Penguin and 1 sumovor, I included a Picture of my collection!
    Oh ya, I just ordered the Robonova 1 with the gripper kit, and I need 1 more Penguin, so when someone comes up with a Penguin Soccer program using a RCA Remote
    "Hint Hint" I can let the little guys battle it out! LOL
    I tried yesterday at Parallx Component section to find a 3 pin expansion slot so I can use it on the front as you suggested, but could not find one here at all!
    I would Prefer the ones that are used on the boards on the Parallx Sumo Bots they are much shorter and would be better for what I want.
    Any ideas where I may find One???
    Thank you so Very VERY much, Humanoido for all the time and Help!!!
    Rick
    Post Edited (Zax) : 4/21/2008 3:41:24 PM GMT
    900 x 675 - 125K
    edited 2008-04-22 17:54
    Actually, the suggestion was to use a new
    Parallax BoeBot IR detector with long leads
    put into the 3 pin expansion slot on Penguin Robot
    just for testing.
    But first, load in Penguin's stock program
    (see attached) for testing the IR. Then
    switch off Penguin, plug in the detector,
    switch on Penguin, and see what happens.
    If the analytical software I need for IR arrives,
    it can be used to decode the RCA format, but I'll
    need to know which RCA code number works on
    your Parallax remote.
    That's an exceptionally nice robot collection!
    Thanks for sharing the photo.
    humanoido
    Post Edited (humanoido) : 4/22/2008 6:04:17 PM GMT
  • ZaxZax Posts: 48
    edited 2008-04-23 06:06
    Thanks Humanoido the Remote I am using is The RCA UNIVERSAL REMOTE MODEL # RCR311W USING SONY CODE 1036 FROM WAL-MART $8.45 I include a picture. I like the button lay out better then the Parallax remote, Don't get me wrong I am an avid supporter of Parallax Products, and find them seconded to none!! I would like to use RCA remote codes of the following possible ones 1000,1002,1004,1005,1014,1025,1078,1081,1095,1096,1097,1098,1099,1100,1101,1111,1128,1130,1132,1134,1144,1149,1171,1205,
    Thanks again Humanoido
    Rick
    Post Edited (Zax) : 4/23/2008 6:32:04 AM GMT
    900 x 675 - 125K
    That's a lot of codes! Are you controlling everything
    in your house, including the front door? What are all
    these for?
    I doubt the exact same model RCA remote would be
    available in Asia, but strange things do happen and
    maybe it's available. More likely, the RCA codes can
    be developed using the Parallax remote. I will begin
    experimenting with IR flood from multiple remotes
    sending different codes to see if there's significant
    effects and the results of mixing codes and carriers.
    It looks like Erco has already completed some
    posted studies using IR beacons and the results were
    the individual beacons needed some local isolation
    to work and not interfere with each other. For using
    multiple remotes with soccer, there is no option to
    localize the IR from remote to remote and two
    Penguins standing together, so another method is
    needed for use. Maybe the off time of one is used
    as the on time for the other. I would be open to
    learning about previously developed ideas for
    successfully mixing IR.
    humanoido
