Potentiometer in mouse - help needed
Hi everyone
Does anyone know how I could get a potentiometer to replace the phototransistor in a mouse.
Is there an IC or something that can generate the light pulses based on voltage level?
Thank you
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Stickers for sale
Building Blocks To The Propeller Chip
Thank you
To do it you would need a differentiator to say when there was movement and than something to generate pulses whenever the voltage was > some value.
Thank you
Don't know if these are available but it should give you an idea.
I can't find any wireless keyboard and mice kits using rotary encoders for sale.
And I need it to be wireless and I also need the keyboard.
Interfacing a rotary encoder to an optical mouse seams nearly impossible. :-(
