Is GPS accurate enough for this?
This project is in idea phase: (so don't get excited yet)
I'm curious what the accuracy of consumer GPS is, specifically the Parallax module.
How close to actual position am I? Better question would be if I take a note of an
exact position, then return to that position will the numbers match or be close?
I'm considering taking my Portable prop to the next level using my eyepiece screen
and GPS to create a simple game with virtual tasks in a real environment, say like
the local park. If I can make this work, I think that vision (LCD) glasses might be
the next step.
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
the next step.
OBC
"On average, the Module has a +/-5 meter position accuracy and a +/-0.1 meter per second velocity accuracy."
It looks like most other GPS Modules are about the same....
Of course, if you can afford a differential ground-base http://www.oxts.co.uk/default.asp?pageRef=91 then you can get 'pretty good' accuracy...
Don't visit my new website...
I don't know your exact purpose, but....
one of my hobbies (when I have time) is called GeoCaching. Basically it's a high-tech scavenger hunt. People hide a waterproof container and record the GPS coordinates of where it's hidden. Then they post these coordinates to a website along with some hints and challenge people to find it. There's usually a log sheet to sign when you find it, and sometimes a prize(think gumball machine prizes) there's more to it also, see www.geocaching.com/ for more details.
We use handheld GPS units for this. and it usually gets you within 5-10 feet. So it depends on what your idea of "a simple game with virtual tasks in a real environment" is.
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
Brian
Sheesh!
They only list about 120 in my area...
And 8 of those are mine.
My Geocaching nick is 'Gadgetman!'.
(No surprise there)
I had always envisioned building a Robot that could lead me to the GPS coordinates......
