IR Remote for Boe-Bot
I need help programming a remote that I have into the Boe-Bot. I don't know how to program remotes at all so please help! I want the right arrow to make the Boe-Bot go right, left arrow to make the Boe-Bot go left, ect. I have like 4 remotes the·1 I was planning using is·for a NEXUS TV. Thanks!
Dan Taylor
Post Edited (Dan Taylor) : 4/10/2008 4:19:59 PM GMT
Dan Taylor
See http://www.parallax.com/dl/docs/books/edu/IRRemoteBoebot.pdf·· That's·a big download, so cut to the chase at Appendix 1, page 159.
P.S. Thanks for posting!
Dan Taylor
Dan Taylor
So, find a device made by Sony in that list (they make TV's, VCR's, DVD players) and using the procedure outlined in the pamphlet, set the "universal" remote so it can control a Sony TV set.
If you don't have that pamphlet any more, and can't find it, then buying a new universal remote that HAS the pamphlet is like $10 at Radio Shack.
On the other hand, if you DO have a Sony TV remote, you can use that.
And it can't really detect the Boe-Bot.
Dan Taylor
So, it's off to Radio Shack then?
Dan Taylor
If I were you, I would read all the info from the link I sent you earlier. Go straight to Appendix A, and work slowly and carefully through the very first sample program called irremotecodecapture.bs2 . It shows you a live display of what codes the Stamp or robot is receiving on your PC. Even if your remote is not set to Sony TV, you will probably get some response to a few of the remote keys. Once you have that working, you can verify the Sony codes and fill in the rest.
Dan Taylor
So you need to give more data -- attach the BS2 code, tell us the brand name of the remote and where you got it, something. Otherwise, I've already given you all the ideas I have so far.
Dan Taylor
- Stephen
Dan Taylor
http://www.parallax.com/Store/Accessories/Tools/tabid/162/CategoryID/37/List/0/Level/a/ProductID/63/Default.aspx?SortField=ProductName%2cProductName
