Wiznet Contest Results
Well....the results of the WIZnet design contest are in at Circuit Cellar.· Check them out here: http://www.circuitcellar.com/wiznet/
I signed up for a module and had the intent of making an entry or two, but time got away from me (isn't that always the case?).· Several ideas I was kicking around were implmented by others.··My ideas included a controller/datalogger for watering, temp, humidity sensing system for hybroponics, an ethernet to·DMX512A system (I was really surprised to see someone do this as an entry), and a·ethernet enabled picture frame (was REALLY suprised to also see this).· There is a wealth of information in the abstracts and entry material.· It is neat to see how the projects were implemented and compare it to my design sketches.·
Sadly, no Parallax micros in any of the winners.· I was going to use the Propeller, but again time got away from me.· Seeing these projects makes me want to finish a couple of the ideas I had.
Timothy D. Swieter
www.brilldea.com·- check out the uOLED-IOC, an I/O expansion for the uOLED-96-PROP
www.tdswieter.com
One little spark of imagination is all it takes for an idea to explode
Timothy D. Swieter
www.tdswieter.com
Paul Baker
Post Edited (Paul Baker (Parallax)) : 4/10/2008 1:26:12 AM GMT
Timothy D. Swieter
www.tdswieter.com
