EEPROM verify error
What could be causing this error when I try to download to eeprom?
"EEPROM verify error on COM 8."
More importantly, how can I fix it?· I can download fine to RAM and run the code just fine.· Just not to EEPROM (I checked, it isn't downloading correctly).
Thanks.
At least I have extras [noparse]:)[/noparse]
I did measure all pins on the eeprom with voltmeter and also with ohmmeter but all seems ok. That was very strange for me, but the eeprom could not be the problem while it was working on the other board.
Then I resoldered all eeprom pins again and the problem was fixed. Perhaps this will also help you. Good luck!
