Prop tool on OSX/Linux
Hi everyone,
I finally got a prop proto board! I was really excited to get started with it, until I went to download the prop tool. It only comes as a .exe file. I don't have a windows pc. Please get it working on non-windows systems. Tech-savvy people (aka parallax's customers) tend to use non-windows OSes anyway, and the number of non-windows users has grown alot since the new get-a-mac commercials and vista's hardware requirements came out. Has anybody tried using it with wine?
Just a suggestion.
Just a suggestion.
wine: search.parallax.com/search?ie=&q=%2Bf%3D25+-ord%3Dd+wine&site=parallax&output=xml_no_dtd&client=parallax&btnG=Google+Search&access=p&lr=&ip=98.195.101.68&proxystylesheet=parallax&oe=&filter=p
linux: search.parallax.com/search?ie=&q=%2Bf%3D25+-ord%3Dd+linux&site=parallax&output=xml_no_dtd&client=parallax&btnG=Google+Search&access=p&lr=&ip=98.195.101.68&proxystylesheet=parallax&oe=&filter=p
Basically, it works partially in Wine. It'll compile, but you'll have to use a third party loader to program your propeller. You may have some luck with VirtualBox or VMWare, but that'll require a copy of windows. I wouldn't hold my breath waiting for Parallax to release a Wine compatible tool (not to mention a native linux toolchain).
I am 1010, so be surprised!
that far on my list of todo's yet. [noparse]:)[/noparse] With the constant requests, perhaps more of us should work on it.
OBC
Edit:
This doesn't look bad either...
http://www.virtualbox.org/
Here's a setup video
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook 1.4
Updates to the Cookbook are now posted to: Propeller.warrantyvoid.us
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
Post Edited (Oldbitcollector) : 4/4/2008 2:41:54 AM GMT
The more I know, the more I know I don't know.· Is this what they call Wisdom?
What version of windows did you install on VirtualBox?
Doug
I've had it working for _ages_ on x86 linux using Virtualbox.
I've used it with 2k and XP as guest OS and had zero problems programming via USB.
I've also had it running with WINE (though it won't load the prop) but my wine setup is pretty complex and uses odd DLL overrides and other black magic to hold it together.
Day-to-day I just us it on XP under VirtualBox.
If you have an old copy of 2k or XP lying around, Virtualbox is free... Just do it [noparse]:)[/noparse]
Edit: I also have it running on MacOS 10.4 using Virtualbox and an XP guest. Again, USB programming works..
Brad
A solution to this would be to set up a shared directory using Guest Additions, then set the Python loader on a watchfile in that directory.
I have to say there must be something wrong.. really. I've done Virtualbox on linux with an XP guest on three separate machines with completely different hardware and linux distributions and the FTDI USB-Serial prop plug works flawlessly on all three of them. Can you access a USB hard disk or similar under virtual box? is the USB configuration actually working properly?
Brad
EDIT:
Unfortunately it seams that the larger the program I try to program to the chip, the higher the chance of failure. While this setup worked flawlessly for the small demo programs (blinkenlights), it is quite impossible to use for large programs. Any help would be appreciated.
Note that I had to DISABLE THE USB 2.0 CONTROLLER in VirtualBox in order to get the Demo board recognized.
Also, I used an ueber-stripped-down verion of XP, so it cold-boots in 5sec. This also minimizes any timing glitches.
My setup is Ubuntu 8.04 / Synergy / VirtualBox / LifXP (stripped XP install) / PropTool with USB 1.0 pass-through.
Enjoy!
Attached: proptool being used with VirtualBox's beautiful "seamless" mode (by pressing [noparse][[/noparse]HOST]+L):
Post Edited (Chris Merck) : 5/2/2008 5:13:08 PM GMT
