Multi-Input ADC — Parallax Forums
Multi-Input ADC
ErNaErNa Posts: 1,851
edited 2022-10-05 09:32 in Propeller 1
Sometime there is need to measure more than two slowly changing analog values. This obviously can be done:
3.3V
                            1nF  150kΩ
          adcpin0 ────────┳──╋─────────── Analog In
                     100kΩ 1nF
                   │        Vss
                   │        3.3V
                   │        1nF  150kΩ
          adcpin1 ─┼──────┳──╋─────────── Analog In
                   │ 100kΩ 1nF
                   │        Vss
                   │        3.3V
                   │        1nF  150kΩ
          adcpin2 ─┼──────┳──╋─────────── Analog In
                   │ 100kΩ 1nF
            fbpin ─┻──────┘  
                           Vss
There is one feedback pin which can drive as much 100 k resistors in parallel and more than one input can be used as comparator inputs. The active inputpin can be selected on the fly and after waiting some time, the selected analog input stabilizes and is not influenced by the other inputs. Following just my simple test software in Spin.
[code]
' Test MUX-AD-Converter: feedback Control Output 23, Inputs: 20, 21, 22
ADCOutPin := 23
ADCInPin := 22
DIRA[noparse][[/noparse]23]~~ ' Pin 23 Control Output
CTRA := %01001_000 << 23 + ADCOutPin << 9 + ADCInPin
FRQA := 1 ' Modus f
ModEdit: Add image of ASCII art
  • RaymanRayman Posts: 16,271
    edited 2008-04-02 10:19
    This is an interesting idea...· I guess it could work OK.
    Post Edited (Rayman) : 4/2/2008 10:30:38 AM GMT
  • ErNaErNa Posts: 1,851
    edited 2008-05-18 19:23
    OK, it works and I just modified the code a bit:
    CON
      ADCNmb    =  3  ' Number of inputs to scan
      ADCOutPin = 23  ' Control output in for ADC
      ADCInPin  = 20  ' First input Pin, ADCNmb consecutive pins
    DAT
      ADCIdx      long  0     ' Index of Input
      ADCMux
      ADC_MuxV0   long  0     ' value of input 0 during measuring time
      ADC_MuxV1   long  0     ' and so on
      ADC_MuxV2   long  0     '
      ADCStrtTime long  0     ' start time last conversion  ADC_Values             ' analog values  normalized
      ADC_Value0  long  0
      ADC_Value1  long  0
      ADC_Value2  long  0
      if  cnt - ADCStrtTime >  clkfreq/50 ' every second fifty times, if you like
         ADC_Mux[noparse][[/noparse]ADCIdx]     := phsa - ADC_Mux[noparse][[/noparse]ADCIdx]
         ADCStrtTime         := cnt  - ADCStrtTime
         ADC_Values[noparse][[/noparse]ADCIdx]  := ADC_Mux[noparse][[/noparse]ADCIdx] / (ADCStrtTime /1000)
         ADCIdx              := (ADCIdx+1) // ADCNmb
         CTRA := %01001_000 << 23  +  ADCOutPin << 9  + ADCInPin+ADCIdx  ' activate next control input
         ADCStrtTime         := cnt
    This gives quite stable values and the module can be integrated into a loop with varying runtime. I didn't think about to optimise the memory consumption, only try to make it working burger.gif
  • Ken PetersonKen Peterson Posts: 806
    edited 2008-05-19 13:19
    We did that a few months ago on a project that we did because we ran out of pins. I don't know how our code compares to yours, but it is a very workable approach.
