Synth.spin square wave generation question — Parallax Forums
automatonautomaton Posts: 12
edited 2008-04-02 07:28 in Propeller 1
Hello,
I·need to generate a high megahertz freqeuency·square wave·(between 1 and 10 mHz... all within that range)with a 3.3 volts peak to peak.· So i busted out the synth.spin, but to my dismay it was only putting·out around .5 volts peak to peak.· Its also a bit jittery.· Is there a reason for this?·
I suppose I could always use a seperate oscillator or crystal to generate a clean·square wave within my desired voltage ragne, but I've never directly worked with a crystal before, any suggestions on how to go about creating a square wave with 3.3 Volts between 1 mhz and 10 mhz?·
I was hoping for a MCU to do the job so that I could modulate the outpout frequency to any given value within my range.·
I've attached a picture of the square wave generated by synth.spin (imag0081.jpg.· Can anyone give me a suggestion on why the propeller is doing this or any alternatives?
Post Edited (automaton) : 3/31/2008 8:54:30 PM GMT
    edited 2008-04-01 02:45
    What is the volts/div setting for the picture you posted? You sure it's 200mV and not 2V (just asking the obvious). You are getting alot of ring on your signal, this is typical of an inductive trace. I don't know what your setup is, but some things may be acting with each other to form a low pass filter and has attenuated your signal.
    PLLs work on powers of two, frequencies other than a power of two ends up spliting the difference. This is jitter, and all PLLs exhibit it to varying degrees and the higher the frequency compared to the base frequency the more it's apparent. You will need to turn to more traditional methods of function generation if you need to have low jitter signals.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 4/1/2008 2:54:52 AM GMT
  • datacpsdatacps Posts: 139
    edited 2008-04-01 03:31
    Paul in the synth Spin I see it can go up to 125 Mhz dc. all I need is up to 30Mhz. I am going to use a oamp to boost my signal to drive my mosfets. I need square waves because my project involves harmonics. in the synt.spin
    are there square waves or triangle waves being produced. I need 30Mhz square waves from the prop. I don't want to use a dss chip I would like to use the prop for all my projects if I can...
    edited 2008-04-01 03:42
    Sorry! I did not finish my last post before I accidently sent it..
    With my scope I got good square waves up to 10Mhz but it started to look like a saw tooth wave past the 10Mhz. Thanks
  • Beau SchwabeBeau Schwabe Posts: 6,574
    edited 2008-04-01 04:46
    automaton,
    You should be getting much more than 0.5V and as Paul suggested, you are getting a lot of ringing which could be typical of inductive traces. The low voltage could be a sign of a bad ground connection even ground loops.· Make sure that your scope is connected on the same AC power as your PC,·Propeller board, etc.. and also make sure that the proper AC polarity and grounding is observed between the Propeller and your scope.
    datacps,
    "With my scope I got good square waves up to 10Mhz but it started to look like a saw tooth wave past the 10Mhz." - This may depend on the capabilities of the scope, and not the output of the Propeller. I have a 100MHz scope and I see similar characteristics at about 50MHz. However the same program running in Chips office on his high end scope, and the edges are perfectly clean.
    Beau Schwabe
    IC Layout Engineer
  • automatonautomaton Posts: 12
    edited 2008-04-01 07:50
    Beau, Paul,
    Yup, I'm positive its is .2 V/div. To verify that its reporting the correct voltage, I ran the probes and the Oscope against its calibration· pins at that same volt/div and it correlates.· So·I'm getting that .5volts from visual inspection of that first spike (analog scope), but the majority of the information is below that.·
    Anyways, as for the setup: Propstick USB, frequency is 2.5 mhz (or 5 mhz, I'm using both for experimentation purposes),·5 ~ 9 V (I've tried multiple voltage levels), standard breadboard, and a 465 Tektronix Oscope (an oldie but goodie).
    The Oscope and the DC power generator are on the same ground, the generator is pumping in that voltage on pins 9 for Gnd and 12 for Vdd, I am also sending the frequency out of Pin 3.· There is no load on the propstick regulator.
    To verify that the voltage I'm getting off of the Oscope is correct, on a whim I also hooked up a multimeter (at those frequencies, I'm assuming the multimeter should read a constant value since its sample rate is so low in comparison)... and it also reports the same mV value where· the majority of hte signal information lies... so thats some sort of comparison and validation of the Oscope.·
    Just to play around with it I thought I'd hook it up to a 1K resitor, and it seems to have cleaned the signal quite drastically and has removed the ringing from the signal. Currently, with the·ringing fixed... I suppose I could send the square wave through an opamp go get the voltage range I need and be done with it, but i'd really like to know why the voltage isn't very high.· At least its stable in the sense that it is·repeating constantly and not fluctuating wildly from peak to peak.· But I'm not all that confident that the ringing is permanently fixed.
    So I've attached the smoothed square wave and a picture of the setup.· Any help on what I'm doing wrong here or what I can do to fix it would be of help.· Thanks.
    2048 x 1536 - 635K
    2048 x 1536 - 540K
    edited 2008-04-01 15:14
    automaton,
    I'm just curious.... "...I am also sending the frequency out of Pin 3" , but the '94' image shows the resistor connected to P2.· Are you counting Pin0 as a valid pin number?
    When I send a signal on P3 and connect a scope to P2, I see about a 160mV Pk-Pk signal at the correct frequency due to pin coupling effects.
    What happens if you simply just make the Pin an Output and High? … or switch to a different pin?·· …What does the voltage read then?
    Beau Schwabe
    IC Layout Engineer
  • RaymanRayman Posts: 15,895
    edited 2008-04-01 15:51
    I was curious, so just hooked it up to a scope on P7 with FrequencySynth.spin set to 10 MHz... I get the full 3.3 V amplitude square wave. Don't see much jitter...
    Do get ~200mV on P6 though.· So, I'd guess you're on the wrong pin too.
  • HarleyHarley Posts: 997
    edited 2008-04-01 15:59
    The 'A0...A31' I/O so-called pin numbering vs the actual IC's physical pin numbering has thrown me a number of times.
    Off by one on the low pin numbers, then progressively off by more and more towards the end.
    Harley Shanko
    edited 2008-04-01 21:31
    Okay, I'll check and verify the code to make sure it matches with the pin I've connected to when I get back home. I was just counting from the top when I said pin·3.· I will check the code though and·report back·... hehe, I sincerly hope I wasn't that stupid (I may be smacking head into wall.. I feel a quote from Homer Simpson·might be appropriate here).·
    I also have another·spare propstick I can plug in and·see if its just a damaged propstick, something I didn't try yet.···
    edited 2008-04-02 04:58
    I'm happy and proud to report that the low voltage issue was due to my stupidity! my code did not corespond to the pin that i had tapped.· too bad there isn't an emoticon for smaking my head on the wall.· redface.gifblush.gif
    But the ringing effect is still present.. I can clean that one up pretty easily though.
    Thanks for catching my mistake.. Doh!
    automaton,
    Glad that you got it working... lol
    Beau Schwabe
    IC Layout Engineer
