template for driver
Hi all....this is the "idea of 6 PM" after an heavy day.
I will start writing my first driver ever for a e-ink monitor from PVI (does anybody have one ready
)...I am trying to build a little background before killing the display and I thought...driver is about timing, pins assignement and basic functions (init, write, read...send command..send data) etc etc...
Is possible there is no tool to quickly develop drivers? Does any "template" exists?
I assume I am too tired if I am thinking of that...
What is your idea?
·-- Nicola --
)...I am trying to build a little background before killing the display and I thought...driver is about timing, pins assignement and basic functions (init, write, read...send command..send data) etc etc...Is possible there is no tool to quickly develop drivers? Does any "template" exists?
What is your idea?
·-- Nicola --
If you do have to write a drive start with a good flow-chart or pseudo code. After you have done this and have a good algorithm you can think about writing some code either in spin or assembler.
