Where can I find gears for stepper motor? 3mm shaft
Hello,
Where can I find a good source of gears to fir the Parallax Stepper motor? The documentation says it has a 3 mm shaft.
I want to make a computer controlled "analog" clock and am thinking of gearing down the output to count seconds.
http://parallax.com/Store/Accessories/MotorServos/tabid/163/CategoryID/57/List/0/Level/a/ProductID/65/Default.aspx?SortField=ProductName%2cProductName
wabbit
wabbit
Do you have one of those motors in hand? The reason I ask is that the photo on the product page shows it with a gear already attached, although neither the product description nor the spec sheet mentions it.
Correct me if I am wrong (this is my first time calculating gear ratios) If the stepper motor turns in 7.5 degree increments then I need to set up a 1.25: 1 gear ration to make the out put turn in 6 degree increments.
http://servolink.com/prices.htm
Chris Savage
Parallax Tech Support
