Where can I find gears for stepper motor? 3mm shaft — Parallax Forums
wabbitwabbit Posts: 16
edited 2008-03-19 15:27 in General Discussion
Hello,
Where can I find a good source of gears to fir the Parallax Stepper motor? The documentation says it has a 3 mm shaft.
I want to make a computer controlled "analog" clock and am thinking of gearing down the output to count seconds.
http://parallax.com/Store/Accessories/MotorServos/tabid/163/CategoryID/57/List/0/Level/a/ProductID/65/Default.aspx?SortField=ProductName%2cProductName
wabbit
  • wabbitwabbit Posts: 16
    edited 2008-03-19 03:13
    eh? Do gears for rc car motors work? It looks like htis motor comes with a pinion gear installed from the picture
    edited 2008-03-19 04:16
    wabbit,
    Do you have one of those motors in hand? The reason I ask is that the photo on the product page shows it with a gear already attached, although neither the product description nor the spec sheet mentions it.
    edited 2008-03-19 11:49
    no I dont have one yet. I am going to order one this weekend, but I want to get some gears at the same time. I want to use it to make a clock that just shows hours for now so I need to reduce the gearing to make it turn in 6 degree increments (minutes)
    Correct me if I am wrong (this is my first time calculating gear ratios) If the stepper motor turns in 7.5 degree increments then I need to set up a 1.25: 1 gear ration to make the out put turn in 6 degree increments.
  • bobledouxbobledoux Posts: 187
    edited 2008-03-19 14:50
    We carry the Stepper Motor for educational purposes to demonstrate control using our Microcontroller. To that end this Stepper Motor is included in the Stamp Works kit. However, the motor make/model is subject to change and we don’t necessarily have detailed specifications for the ones we have. My advice would be to buy a stepper motor based on the specifications you need for your application, such as voltage, current, torque, degrees/step, etc.
