PINK Flash Variables
I have looked around and cannot find any information on this topic.· When a pasic stamp or prop writes a variable to a PINK it only loads it into RAM.· Is there any way to write the information to the flash ram via serial command?· I know it can be done via web interface, but I need the microcontroller to write it.
"A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
DGSwaner
Chris Savage
Parallax Tech Support
