PINK Flash Variables — Parallax Forums
Computer Geek 101Computer Geek 101 Posts: 179
edited 2008-03-14 20:31 in General Discussion
I have looked around and cannot find any information on this topic.· When a pasic stamp or prop writes a variable to a PINK it only loads it into RAM.· Is there any way to write the information to the flash ram via serial command?· I know it can be done via web interface, but I need the microcontroller to write it.
  • DgswanerDgswaner Posts: 795
    edited 2008-03-11 15:51
    I don't think so, what you could do is store them in the eprom of a stamp. Then upon power failure or restart, rewrite the variables to the pink
    "A complex design is the sign of an inferior designer." - Jamie Hyneman, Myth Buster
    DGSwaner
  • Computer Geek 101Computer Geek 101 Posts: 179
    edited 2008-03-11 16:43
    Thanks Ill give that a go.
    As per the documentation writing to flash can only be done via the web interface. Take care.
