Has anyone ever thought about porting SPIN to the PC?
I know that this is a very strange question, but after playing around with this language I find that I REALLY like it! I understand that its current implementation is limited by the Prop, but that wouldn't be an issue in Windows. I think it would be a fun and rather easy OOP language to work with outside the Prop, with suitable expansions and features necessary for Windows.
Anyway, enough crazy rambling.
·With vbasic, C, C++ available free it may be a fun project but not alot of need out there.
·If it floats your boat, go for it...
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
did you ever take a look at Delphi ?
c++ is more cryptic to read than Delphi. Compared to SPIN Delphi has much more OOP Opportunities !
What's better in SPIN than in Delphi is the effective way of creating blocks of code by indenting
Here SPIN forces everybody to write in a good formatted way
In Delphi you have to write
begin .... end for every block
So a Delphi derivate with indenting instead of begin ... end would be my absolute favorite for programming on PCs !
greetings
Stefan
Spin is entirely self-contained. Its only I/O through the Special Purpose Registers and limited Cog peripherals. Any complex I/O implemented by bit-banging the very same where timing is everything.
How and what to map to the outside PC environment is key to purpose and I personally couldn't see it.
Spin on another microcontroller, that I can see as having a use.
Given the right kind of tools, one could design and test their entire system in the virtual world of the PC without having hardware. If a generic hardware solution like a boe-bot or something more robust is physically available with net access for example you or anyone else could test the design a world away. May need constraint, a web cam, and a battery charger.
jazzed·... about·living in·http://en.wikipedia.org/wiki/Silicon_Valley
Traffic is slow at times, but Parallax orders·always get here fast 8)
Paul Baker
Chip Gracey
--Chuck
--Chuck
Quite a few I would expect for an 8-bit but others may fare better. The advantage of most modern micros is that that they have quite large memories these days so interpreter code size isn't that much of a problem.
Execution time is a different matter.
Most micros are single-core so while Spin-only is perfectly feasible and useful in many circumstances ( probably no worse than PBasic performance - gut feeling ), the real power of Spin comes with the Propeller itself. Multiple Spin Cogs can be emulated but that impacts performance although it still has its advantages. CogNew provides a very easy and easy to understand means of enabling multi-tasking.
Whether to also emulate PASM ( not the existing ROM interpreter written in PASM unless one wants a slow system ! ) is a debatable issue as I don't see it would deliver anything useful; most PASM is for specific purposes and requires the timing a Propeller gives. Allowing multiple Cog emulation with native assembler could have some purpose but would still have limited use. Something like the Virtual Peripheral approach of Javelin may be an alternative there. Both would be a deviation form Spin as we know it.
Another issue is RAM, but there's no reason Spin bytecode could not be executed directly from external Eeprom albeit relatively slowly. Real RAM can be virtually mapped to where it would be above the bytecode image. As self-modifying of Spin bytecode is a very rare case it wouldn't be necessary to have 32KB of RAM, but the more the better. A purpose built downloader could copy an .eeprom file straight to target Eeprom via the target.
A few simple mods to the PropTool or a third party compiler would allow bytecode to be generated to suit any particular target, set constraints and flag when capacity is exceeded. Even without that, the PropTool can still be used for program writing.
Ultimately there's no reason a network of cheap micros could not be used to give true multi-Cog emulation as fast as they can ( high-speed comms and a common I/O block ), nor any reason that FPGA could not be used ( that could emulate PASM and even run the ROM Interpreter ) but that's moving towards being more of academic interest where a genuine Propeller would better fit the bill for most people.
It's not really about competing with the Propeller though - it has its own USP's which would be hard to match - but about leveraging what Spin gives more than anything else.
I'd second that. Python, IMHO, is is about as similar to SPIN as you'd want on a computer. Anything more, and I think you'd be kinda limited.
Craig
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
