Interesting chips
I am using this chip in a prototype (though I most likely won't use it in the final design), but it's interesting enough to share. It's actually·2 chips from New Japan Radio (NJR aka JRC) the·NJU7312 and NJU7313. These are analog switches but are configured in interesting ways. They are configured as a 4xSP3T·+ 2xSPDT, and a 2xSP4T·+ 4xSPDT respectively. While thats not really impressive, it appears any branch can be connected to the pole at any time. By connecting different switches together you can create complex communication bridges.·Also the interface is 2 wire SPI and one of each chip can share the same bus, though it's top speed is 100kbps and 14 bit packets (update 8 of the 16 branches a little over 7000 times a second) so it's not good for high speed switching. The datasheet is a little light on some·information (such as channel capacitance), so I'll have to test it.·Mouser stocks the parts.
Paul Baker
Paul Baker
Thanx
Also, are they avail at mouser or any American Company?
······· "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
Paul Baker
PLEASE CONSIDER the following:
Do you want a quickly operational black box solution or the knowledge included therein?······
I really want to connect multiple inputs to a single op-amp then to the ADC.
I know nothing about i/0 expanders but from what I read they would be digital expanders and I need an analog expander.
Thanx
This maybe what you are looking for
http://atic.phys.lsu.edu/aces/Docs/Component%20Docs/adc0831.pdf
Now can you use the Demo Code that is for the ADC 0831 on a
ADC0832 2-Channel MUX..·or ...·ADC0832 4-Channel MUX·..or
.. ADC0832 8-Channel MUX....... I do not know......>
All·I can tell you is about the ADC 0831·which·I·have only played with
I·have not try these other ·chip yet but i will
I will need a 2-Channel· for something that i am working on
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/28/2008 9:29:02 PM GMT
I want to avoid the multiple op-amps and just run 12 wires to a chip to the op-amp. When I get to 12 op-amps, I am afraid of noise and temperature variations that will kill me in terms of accuracy. With one op-amp, I can calibrate each channel thru software.
That is why I am looking for a simple switching device to go from one thermocouple to the next. Since I have only been back into electronics for about 2 months, I have no idea what they would be called.
Think of a simple rotary dial. I rotate and change inputs. I want to do this rotation electronically but have no idea what it would be called but the chip Paul suggests seems to be what I am looking for.
· I looked at the datasheet and it's Japanese to me.
Thanx
Post Edited (mosquito56) : 2/28/2008 9:42:19 PM GMT
Paul Baker
· You mentioned 4spdt. Switches I can understand but will they pass a voltage staight across or are they only for digital info? I.E. Hi,low?
· If it's digital, is there any such thing as an electronic "rotary" switch?
·Mike, what kind of adc can read 0 to 63mv? Everything I've read on thermoucouples has shown an op-amp to boost the voltage up to the normal 0-5V range. I am normally wrong.
· Most thermocouple modules are expensive. The maximum is $7.65 each up to a 100 qty.It is a k thermocouple specific chip and has the op-amp built in. ·The parallax module is $32 for a 3 channel I think module. Needing 12 wires starts getting expensive, but since the aircraft engine cost me $20,000 a couple hundered extra is not a problem. I don't plan to start the engine for a couple more months so I will just take it one step at a time.
·Right now I have one k thermoucouple wired to an op-amp to a adc0831. It seems to be working but I haven't ordered the temp gun yet to calibrate it. Hope I can get by without a lookup table. ·Someone suggested a couple months ago to get the ·max1270, it has 8 adc inputs. That is my next project.
Thanx for the input. This digital stuff is so new to me it's unreal.
Darn, I just realized I have hijacked Paul's thread, sorry about that Paul.
