propplug drivers [Edit: new PropPlug works] — Parallax Forums
Robot FreakRobot Freak Posts: 168
edited 2008-04-10 15:03 in Propeller 1
Hello,
I've used a USBtoSerial device from parallax, for about 7 months now, with the drivers installed.
Today I installed the PropTool, with the option to also install the drivers.
After that, I connected the just arrived propPlug, the leds flashed a bit, and then went off.
Windows Vista said it was installing the drivers, after a while it said the drivers couldn't be installed.
Then I downloaded the FTDI drivers2.0.0 from the website, and launched that.
Vista said the drivers were installed and ready to use, but even after a reboot the leds were still off.
The PropTool recognised it as a COM5 port, but the powered propeller board (switch state 1) couldn't be located.
Any idea's would be great.
Kind regards,
Robot Freak
Post Edited (Robot Freak) : 4/10/2008 3:06:27 PM GMT
  • Robot FreakRobot Freak Posts: 168
    edited 2008-02-28 13:18
    Maybe I should start with an easy question:
    when connecting the propPlug to a serial port, is it supposed to keep a led active?
    Because mine isn't...
  • parts-man73parts-man73 Posts: 830
    edited 2008-02-28 13:23
    No, the LEDs only flash when programming.
    Brian
    uController.com - home of SpinStudio - the modular Development system for the Propeller
    PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
    SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
    edited 2008-02-28 13:25
    Thanks, so that means I've got to check the propTool...
    edited 2008-02-28 14:02
    Still no detection from the propTool.
    The windows hardware manager is showing the propPlug as COM5, no errors.
    The propTool detects COM5, then prompts that no chip is found.
    I've got the protoboard powered by wall power supply, 7.5 volt.
    PropPlug attached with the chips and usb port facing down.
    Kind regards,
    Robot Freak
  • Paul Sr.Paul Sr. Posts: 435
    edited 2008-02-28 14:52
    Robot Freak said...
    Kind regards,
    Robot Freak
    Same setup here (Protoboard, Proptool 1.06, PropPlug (Beenie up) = com5) and works fine.
  • ColeyColey Posts: 1,129
    edited 2008-02-28 15:44
    You say it's 7.5V it is DC isn't it?
    Only reason I say that is some people have fallen fowl of that gotcha already! tongue.gif
    Odds on is that the Propeller chip isn't running.
    PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
    edited 2008-02-28 16:01
    Yes, its DC.
    I'm going to give it a try in a windows XP computer.
    Maybe that will make a difference...
    edited 2008-02-28 17:19
    XP computer can't find the propeller chip...
    edited 2008-02-28 19:44
    Anyone?
    edited 2008-02-28 19:45
    Do you have another board you can test with?
    Paul Baker
    edited 2008-02-28 19:46
    Does it still work with the USB2ser ?
    edited 2008-02-28 19:50
    I've tested with 2 Protoboards, both new ones.
    And yes, the USB2ser is still working.
    edited 2008-02-28 19:56
    Then perhaps it's your Propplug, are you sure it's being connected properly? Are you inserting it with the badge up?
    Paul Baker
    edited 2008-02-28 19:58
    Yes, I did connect it with the logo upwards.
    I used the usb cable that comes with the propPlug, and also an usbcable I always used with the USB2ser.
    None of the combinations works.
    Is there any way to test the propPlug?
    If the propPlug can send a simple signal, I can test it with my Javelin stamp...
    edited 2008-02-28 19:59
    Contact our Technical Support and we'll get a new PropPlug out to you.
    Paul Baker
    edited 2008-02-28 20:00
    I've purchased in the Netherlands, so should I contact Antratek?
    edited 2008-02-28 20:05
    One last thing, you are pluging the PropPlug into the supplied right angle header, and not the usb2ser header correct?
    Paul Baker
    edited 2008-02-28 20:06
    I don't know if antratek accepts returns, If they do not, we can perform the return.
    Paul Baker
    edited 2008-02-28 20:08
    Yes, I used the right angle header.
    I'll contact Antratek to see what they can do.
    Thanks for your help!
    Today the new PropPlug arrived (finally), and everything worked great!
    Vista installed the drivers after two clicks and the PropTool identifies the ProtoBoard.
    So that confirms that the previous PropPlug didn't work.
    Thanks for all replies!
    Kind regards,
    Robot Freak
