propplug drivers [Edit: new PropPlug works]
Hello,
I've used a USBtoSerial device from parallax, for about 7 months now, with the drivers installed.
Today I installed the PropTool, with the option to also install the drivers.
After that, I connected the just arrived propPlug, the leds flashed a bit, and then went off.
Windows Vista said it was installing the drivers, after a while it said the drivers couldn't be installed.
Then I downloaded the FTDI drivers2.0.0 from the website, and launched that.
Vista said the drivers were installed and ready to use, but even after a reboot the leds were still off.
The PropTool recognised it as a COM5 port, but the powered propeller board (switch state 1) couldn't be located.
Any idea's would be great.
Kind regards,
Robot Freak
Post Edited (Robot Freak) : 4/10/2008 3:06:27 PM GMT
Kind regards,
Robot Freak
when connecting the propPlug to a serial port, is it supposed to keep a led active?
Because mine isn't...
Brian
uController.com - home of SpinStudio - the modular Development system for the Propeller
PropNIC - Add ethernet ability to your Propeller! PropJoy - Plug in a joystick and play some games!
SD card Adapter - mass storage for the masses Audio/Video adapter add composite video and sound to your Proto Board
The windows hardware manager is showing the propPlug as COM5, no errors.
The propTool detects COM5, then prompts that no chip is found.
I've got the protoboard powered by wall power supply, 7.5 volt.
PropPlug attached with the chips and usb port facing down.
Kind regards,
Robot Freak
Same setup here (Protoboard, Proptool 1.06, PropPlug (Beenie up) = com5) and works fine.
Only reason I say that is some people have fallen fowl of that gotcha already!
Odds on is that the Propeller chip isn't running.
PropGFX Forums - The home of the Hybrid Development System and PropGFX Lite
I'm going to give it a try in a windows XP computer.
Maybe that will make a difference...
Paul Baker
And yes, the USB2ser is still working.
Paul Baker
I used the usb cable that comes with the propPlug, and also an usbcable I always used with the USB2ser.
None of the combinations works.
Is there any way to test the propPlug?
If the propPlug can send a simple signal, I can test it with my Javelin stamp...
Paul Baker
Paul Baker
Paul Baker
I'll contact Antratek to see what they can do.
Thanks for your help!
Vista installed the drivers after two clicks and the PropTool identifies the ProtoBoard.
So that confirms that the previous PropPlug didn't work.
Thanks for all replies!
Kind regards,
Robot Freak
