P.I.N.K. to wireless ethernet?
Help.
Is there a device that will act like an ethernet to wireless adapter? What I need to do is connect a PINK to a wireless network. I need something I can plug the PINK into that will then connect to the wireless network. I've seen some cheap devices (and I need something <$50) referred to as access points and bridges, but it's not clear if this would do what I need.·My router is a Linksys WRT54G (Wireless-G).
Thanks for any info.
- Rick
- Rick
Craig
My system: 1.6 GHz AMD Turion64 X2, 4GB DDR2, 256MB ATI Radeon Graphics card, 15.4" Widescreen HD Screen
I have a duel boot of Ubuntu Linux and Windows Vista. Vista, because it came with the PC, Ubuntu because I like software that works.
"Failure is not an option -- it comes bundled with Windows."
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
Windows for Solitaire
Nick
If you can access the Pinks webpage from your private network, you can forward port 80 through your router and modem, then access the PINK via your WAN IP. Then, you can set up a Dynamic DNS account, and access the PINK via a domain name.
Craig
Use The Best...
Linux for Servers
Mac for Graphics
Palm for Mobility
but my provider blocks port numbers lower than 1024.
So, can i modify the port number of the pink so i can forward it in my router?
Regards
Luc
