External On/Off and Reset for the Protoboard?
···· I finally got my protoboard working and put it into a radioshack project box (having fun with the demos, etc.), but I don't want to keep having to open the box to turn on or reset the propeller. I bought a switch and a reset button, but I noticed that the protoboard doesn't have anywhere I can connect the reset button, and uses a switch with a lot contacts than my switch has. I was thinking of connecting my switch before it gets to the switch on the board, and soldering to the tiny reset switch. I just wanted to know if there was a better way to do this. Thanks.
Attached is a part of the Protoboard schematics with th parallel switch in red.
If you also need the Servo-Voltage (third position of the on board switch) then make also the green connection.
Andy
