How to choose resistors in a Programmable Gain Amplifier — Parallax Forums
Paul BakerPaul Baker Posts: 6,351
edited 2008-02-23 06:14 in General Discussion
Sometimes analog amplifiers with multiple gains are needed in a design, the most straight forward way to do this is to construct circuits in parallel and choose which amplified signal to measure. But if you need the gains to be·strongly correlated with each other then parallel is a bad choice. Not only is there mismatch from the ratio resistors, but differences in offset voltage between multiple amps, bias current etc all effect each gain in seperate ways. Programmable Gain Amplifiers help with this by providing many different gains on one amplifier by using a resistor ladder and an analog multiplexer. The series method has the advantage of allowing analog multiplexors with a significant resistance because it is a very low current path. Calculating the resistor values can be daunting, but there is a simple solution using linear algebra, you don'tneed to understand how it works, just cookbook it and you'll get the answers.
Here's the article which discusses it: http://www.edn.com/contents/images/6356067.pdf
Paul Baker
Post Edited (Paul Baker (Parallax)) : 2/4/2008 8:18:30 AM GMT
    edited 2008-02-05 02:12
    Eek, I found an error in my calculations, in non inverting amplifiers the gain is Rf/Rs + 1. The above calculations omit the 1, therefore our starting matrix for the example of 2, 5, 10 is:
     1  1 1
    -1  4 4
    -1 -1 9
    or r = [noparse][[/noparse]1, 1, 1; -1, 4, 4; -1, -1, 9] , perform inv(r) * [noparse][[/noparse]1; 1; 1]*1000 and we get R1=1000, R2=600, R3=200, R3=200 or the 1% resistors 1000, 604, 200, 200 and remembering to add the 1 the real gains are 1.996, 5.01 and 10.02.
    Alternatively a 590 ohm resistor can be combined with a 10 ohm resistor to produce exact gains (within tolerence).
    So, is this stuff going over peoples heads or this just isn't applicable to what people are doing?
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 2/5/2008 2:18:20 AM GMT
    edited 2008-02-05 21:46
    That's interesting, Paul. (Nice use of the Propeller font, too!) I've been using EXCEL for that purpose, in a more or less ad-hoc manner manner to find the solutions. This matrix method is much more systematic.
    The photodiode amplifier that my company sells has 86 distinct gains set by 2 dip switches. Both stages can switch between either straight or split T feedback. The first stage has a transconductance gains of 4000 to 28000 ohms in steps of 4000 and in split T mode from 40000 to 180000 ohms in steps of 40000. The second stage has non-inverting gains from 1 to 8 and also in split T from 10 to 45 in steps of 5. These days 0.1% film resistors are readily available. Much easier than it used to be to find them in thru-hole.
    A second stage of optimization can often find a best combination of resistor values. For example, one choice for an x8 non-inverting amplifier might be 69.8k with 10k. But a better combination is 105k with 15k. It gets harder when optimize whe there are more ratios to match.
    Tracy Allen
    www.emesystems.com
    edited 2008-02-08 04:39
    Interesting approach on your amplifier, definitely beyond my current skill level. This is my first professional analog design so I'm really pscyhed about it. Fortunately we have a spectrum analyzer so I can verify my design. But man I made iniitial assumptions I thought were reasonable that turned out to be out of the question, such as an amplifier with +/- 5V supply, rail to rail in/out, GBWP >= 200 MHz and FPBW >= 20MHz (turns out I can get all but the rail to rail) and finding an ADC with BW >= 20Msps and +/-5V analog supply (closest found is 10Msps for +/-5V, and was beyond target price for part). Definitely a learning experience.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 2/8/2008 4:59:19 AM GMT
    edited 2008-02-09 22:19
    Hmmm. gains steps of 2, 5, 10, broadband, ADC. It sounds like the front end of an oscilloscope? Propeller?
    I do respect the art of achieving the high bandwidth. That is an accomplishment! I do know that rail to rail op amps will never have their full bandwidth near the rails. You may need an booster module to give the +/- 12 or 15 volts, so that the op amps or other circuits can run near the center. But clamp it so that it does not overload the ADC. Almost all rail to rail input op amps have quirks, that have to do with the dual input stage, switching over from the pnp to the npn amplifiers. Differences in bias currents, offsets, and bandwidth. But rrio op amps sure make ee design easier in many situation.
    My multi-gain amplifier is heavily compensated and is designed for accuracy at DC, not for high frequency or pulses. For the highest gains and accuacy, it uses a CAZ rail to rail ouput op amp. On a single supply will pull down to within 5 millivolts of ground, but for some things that is too much, and I have to add a -1.2 volt (V-) supply so that it can go all the way to zero and with decent bandwidth there. Increased bandwidth comes with narrowing the gain choices, more attention to the compensation, and a different choice of op-amp. Always trade offs.
    Tracy Allen
    www.emesystems.com
    edited 2008-02-23 02:58
    Sorry for the delay, got busy and forgot about this thread. Yes it is for the next oscilloscope (working name is PropScope), but the gains are 1, 10 and 100. I got around the rail-to-rail by using +/-7V supplies. I was also finding the opamp buffer for the higher voltages limited in thier FPBW when it dawned on me, a source follower fits all of my requirements for the high voltage input stage. Now I wish I can find a good source discussing switching supplies and thier electrical and electromagnetic noise, or even how to choose component values given certain requirements (I'm speaking of a roll your own solution, while I may choose a chip I want to have a full understanding of how noise on the output is affected by design).
    Paul Baker
  • stevenmess2004stevenmess2004 Posts: 1,102
    What about the ADC used for ViewPort? I don't know the price but that does 40Msps.
    As to the bandwidth, I did a course on opamps last year. Rf/Rs + 1 works really well at low frequencies but it starts to fall apart at higher frequencies. But by the sounds of it you already know that smile.gif The other problem you get is when you are just using banana plugs on you cro leads and everything is on a bread board. It kind of ruins the signal and looses all your gainsmile.gif
    If you can build this for a reasonable price I will buy one.
