RFID door lock
I have a door lock just like the one in the RFID door lock video and would like any info on how to modify mine to operate as the one shown. I am a newbie so please be basic. Thanks for any help.
Pete
Pete
- Stephen
First I would like to welcome you to the Parallax Forum
Have you ever work with a Basic Stamp before
If you have then
First of all do have manual for your lock and dose it have a wiring diagram if so then it should not be that hard for·you
You will need to use a relay to operate door lock motor
If you do not have manual then you have hack the door lock to find what wires·that are use to·operate motor for the door lock
If you have not worked with a Basic Stamp before then
First read through the What·is a Micro Controller and the examples to understand what happen when you different
code examples this will help you alot
··Thanks for any·
Sam
Thanks again and I will let you know how the projects turns out.
Pete
