ESC,LunarX and Propeller
Brian_B
Now we are ready for you prop guys, here’s what we need to do for the Embedded Systems Conference.
Any takers?
Thank's Brian
·"Imagination is more important than knowledge..." ·· Albert Einstein
http://www.diycalculator.com/subroutines.shtml· My favorite website
- 2 cameras· ,one on the rover and one on the Lander
- radio control to the Lander and the rover
- control station with 3 screens, data and 2 cameras
Any takers?
Thank's Brian
send me - let's say 5000$
to clear the details about a contract for a 20%-Participation and AFTER THAT
i start developping it.
Would you send me the money just by nowing my nickname inside here?
surely NOT !
Your call sounds like "we don't know nothing about microcontrollers -
could an expert group develop a superreliable embedded system for free for us?
don't you think this is ultra-hyper-egiostic?
Stefan
I'f I was smart enough to do this myself I would start with a usb camera and a prop demo board.
Thank's Brian
Ask for help and people will come running.
Ask for someone to do all the work for you and you will most likely get a No.
So I will start by giving you some help.
I would not recommend USB cameras as they tend to loose communication with the computer once the cable gets longer than a few meters.
The longest cord I have ever seen on a USB camera was 5 meters and that camera was designed for lego robotics.
I would go with a wireless 2.4Ghz camera.
For motor control use the Parallax H-Bridge.
They can be found here.
They use a servo signal (pwm) and control the speed of standard 12v motors.
If you have any more questions just ask.
Check out my robot using the propeller RECONAUTOR
If you like my avatar then check this out Propeller Domed Sticker
Brian,
Like Steven said if you use the video overlay module from Hitt Consulting you can display information from onboard sensors on the Rover on one of the Camera displays.
Information on the module can be found here.
Just a few questions.
With the control are you planning on having a laptop or a DIY control system?
How far away from the control are you planing on having the rover?
How large will the rover be?
What terrain will it have to manoeuvre over/around?
Post Edited (computer guy) : 2/16/2008 1:46:01 AM GMT
Thank's Brian
Are you thinking of joining the Lunar X Prize?
If so that would be a challenge and I can't find that much information on it.
How do you communicate with the satellite array.
How are you meant to get the information from the array.
It would be nice just to build it for a home project.
How much knowledge with the propeller do you have?
I'm president of PropelX, lunar X prize team. We are filing our letter of intent at the ESC in April. We are displaying a full size Lander and Rover there to try to secure sponsorship. The control system we are working on now is for earth bond testing. I know enough about the propeller to get me in trouble· and have controlled a couple of robots with it. Our first sponsor is CMP, The parent company of EE Times and the ESC.
Thank's Brian
The rules make it a bit hard.
1. HD video feed
2. Has to last a night on the moon (2 weeks).
3. Has to send at least 1GB of data.
4. Has to travel at least 500m.
It will be hard enough to get a robot to land on the moon let alone do the above.
After you register a team, do they give you any more information?
Like what things to buy to get it to communicate.
As for the earth bound testing. It should be fairly easy to do. The only major thing you have to worry about is communication over long distances (greater than 1km).
Good luck and feel free to ask questions.
Thank's Brian
http://forums.parallax.com/showthread.php?p=689306
Max Wooden
Reedley, California
Where the heck have you been
Brian
Thank's Brian
Is it a minimum resolution of any usable kind of video signal encoding,
or only the proprietary patented scrambled DMCA protected HDTV systems they're pushing forcefully nowadays,
which is illegal and infringing to DIY and so must be commercially licensed and equipped at great expense?
Thank's Brian
If your so smart, If the temp on the surface of the moon is 300F .what is the temp 1 inch above the surface?
Thank's Brian
