Nokia Knock-Off
I am new to BS2. I saw on one of the threads that someone made the Nokia Knock-Off run on BS2 code. I was wondering how to hook it up. I have the Carrier Board but I don't understand if you can power it from the bs2 or if I need external power.
Thanks for the support
·This may be what you are looing for
http://www.sparkfun.com/commerce/product_info.php?products_id=569
Look at page two of the pdf file
http://www.sparkfun.com/tutorial/Nokia%206100%20LCD%20Display%20Driver.pdf
I just order one my self so we will see what happens
··Thanks for any·
Sam
Post Edited (sam_sam_sam) : 2/11/2008 1:24:03 AM GMT
Thank You for your reply
I have one and I was never able to get it working with BS2 or BS2P - spent a lot of time tweaking the code with no success.
Did you use the Demo Code that i post and this was the one that did not work
or did you use a diffrent one
I finally wired it up to my Propeller and it worked immediately! Been having fun with it since!
Could you post the code that you used or a link to where i look at and use it
Thanks for any help that you can give me in this matter
··Thanks for any·
Sam
Hello!
Sam_sam_sam how did you connect your device? I presume you're using the Nokia display mounted on the breakout board, as opposed to using the bare device and its connector.
Incidentally this is the same problem I am facing in a later posting concerning the same device. Here it is:
http://forums.parallax.com/showthread.php?t=125223&highlight=nokia
So there we go.
