Smaller than Nano — Parallax Forums
Smaller than Nano
Mike CookMike Cook Posts: 829
edited 2008-02-10 00:18 in Propeller 1
Why would you want to purchase a Spin Stamp for $50 when you can have a Femto Stamp for $20.00?
Not meant to be a flame, just an idea!
Have Fun!
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-02-09 19:28
    You would do that if you have alot of existing hardware
    that is built around a DIP24 socket (to replace basic/javelin stamps).
    regards peter
  • deSilvadeSilva Posts: 2,967
    edited 2008-02-09 19:34
    This is very well done, Mike. I gave my two Proto Boards away; otherwise I also thought doing this some time ago.
    The obvious differences are:
    - This would not fit so nicely into solderless breadboards.
    - If, then there will be 12 I/O lines only easily accessable
    - There is no longer any volateg regulation
    But this will not be an issue in many cases, the differenece of the price tag speaks for itself
    WRT item 2: You can solder female headers at the top of the remaining sides to allow the access to the other 16 lines as well..
  • bambinobambino Posts: 789
    edited 2008-02-09 19:40
    Mike, after seeing how much shorter you cut yours than OldbitCollector, it got me thinking you could do the same with the left over power supply and mouse,keyboard, and VGA. just soldier a few pins and plug it into a bread board.
  • RaymanRayman Posts: 15,953
    I had this same though after seeing what Oldbitcollector did for the mini-DVD hack... I think it makes a lot of sense for setups that aren't going to use VGA and get power another way... I think I would have left one or two more rows of holes all around though...
    edited 2008-02-09 19:41
    @deSilva: Yes that was what I was thinking, on pins P0..P7 and P16..P22 I would install the header on top so I can plug in jumpers to access the rest of the pins from the top side.
    Will fit nicely on a bread board, if you join two bread boards together.
    Yes you'll have to a regulator, but I've got a 3.6VDC lithium battery powered application in mind. Need to add the SD socket and the Xbee!
    edited 2008-02-09 19:43
    This might also a cheap&easy way to put a bunch of props in parallel... Just solder on some headers and stack them up on top of a protoboard...
  • AleAle Posts: 2,363
    Or you can put the pins in DIL format, two groups of 10.. [noparse]:)[/noparse], you keep the foot print. A regulator can be soldered to the other side of the board.
    edited 2008-02-09 19:46
    Xbee, Nice touch!
    I've started implementing SD, but Xbee is just not in the budget.
    Thought about doing it with a right angle header.......Talk about parallel Propeller Processing!
    edited 2008-02-09 19:49
    Shame on all of you! All of this talk has caused me to break out the card and by another Protoboard!
    edited 2008-02-09 19:51
    Mike Cook said...
    ..but I've got a 3.6VDC lithium battery powered application in mind.
    Which works fine... See the discussion we had the last three days wrt rechargeables
    http://forums.parallax.com/showthread.php?p=706724
    I still propose to use a Schottly diode (1N5818) , if you cannot guarantee a limitation of the max charge voltage to - say - 3.8 volts.
    Edit:
    The diode will reduce the voltage by 0.3 V so you can use the more efficient overloaded area (which can always happen when you are not very careful with the loading process!) rather than the other end. The Prop will stop at 3V, corresponding to 3.3V with a Shottky diode, which is still fine for any battery.
    I enclose a typically discharge curve for a 3.6 V scenario, meassured by myself during a long sleepless night; so the current drawn was most likely 150 to 200 mA ... I do not remember any longer.. Some LEDs were on .. 8 or 10...
    Post Edited (deSilva) : 2/9/2008 9:32:49 PM GMT
    573 x 244 - 27K
    edited 2008-02-09 19:59
    @ bambino: Come on get five while your ordering! I'll bet if we can 'rally' Ken G. we can get him to offer a 6 Pack of proto boards for $100!
    @ deSilva: Agreed a Schottly diode would probably be in order for a standard lithium battery, however I've been playing on the wild side and have not been using the recommended voltage translation fro 3.3vdc to 5vdc voltage translations! Note: your mileage and component burnout may vary! Been lucky so far!
    edited 2008-02-09 20:03
    Mike, I was thinking of putting in a delta sigma for a micrphone; With the unregulated battery supply it would be pretty useless wouldn't it?
    edited 2008-02-09 20:09
    Bambino
    I'm not that familiar with delta sigma, so I can offer any advice there, however there are loads of other smarter people that frequent here so they might have a comment.
    I needed a cheap small platform to do various tasks, normally the proto board is adequate, but sometimes I needed to package my projects in a smaller package. I haven't built anything that has gone to production, just gadgets!
    Note to self: this is a nice size to fit in a model rocket!
    edited 2008-02-09 20:22
    Maybe Oldbitcollector needs to add this to his web site.......This is defiantly a warranty VOID!
    edited 2008-02-09 20:27
    Oh, I bet he will.
    Just as soon as he gets his wish for 36 hour days!
    edited 2008-02-09 21:03
    FYI!
    If anyone is thinking about doing this modification then let it be known that RES is NOT brought out. You'll have to use an unused pad to connect RES. I used the pad next to P31. This way you'll be able to program the Propeller.
    555 x 540 - 187K
    edited 2008-02-09 22:16
    Hey Mike,
    Here's a trick you might not be aware of: For tackng down wirewrap wire modifications, I use clear nail polish. It's tidy, dries fast, and is almost invisible. (It's rather permanent, though, which may be why you used tape.)
    'Just thought I'd mention it...
    edited 2008-02-09 22:19
    @Mike, On the Boards! Would if I could, but the lady in the kitchen is real handy with a knife.
    I do wish they could bring back the six packs! I'll put off my purchase for a bit and see if they do. I'll paypal you for one if you want to break open a pack. I know the LCD hack has boosted their sales, it's only logical the protoboards are going to benifit as well. When I bought my LCD it was only 12.95 and now(after Oldbitcollectors hack) there selling for 19.95. And since the company is bottoms up, They may get higher!
    @Phil
    Great idea, I have a bottle of nail hardener that I use. Be carefull though the first kind I tried had some conductivity in it!
    Post Edited (bambino) : 2/9/2008 10:24:05 PM GMT
    edited 2008-02-09 22:20
    One more note............
    Using the Propeller Tool I was able to load a program via F10. However I was getting an error when I tried loading a program to EEPROM using F11. So since my big sander probably cut through a trace I had to add a jumper wire from VSS to VSS, not a big deal.
    Post Edited (Mike Cook) : 2/9/2008 10:29:49 PM GMT
    699 x 710 - 282K
    edited 2008-02-09 22:23
    I haven't cut my board yet, I'll see if I can work around the grounds.
    edited 2008-02-09 22:26
    Phil,
    Agreed clear nail polish is wonderful stuff! I've been educated!
    I know this since I'm the only male out of four female cats, one female dog, and two other female humans in my family (Wife & Daughter)!
    Used the 'Magic' tape since it was handy!
    edited 2008-02-10 00:10
    Geez, I go out for a family day and you guys break out the saws!! Nice work Mike!
    I've got my sanded down, and yes I wanted enough room to added the resistors for the video and audio connections,
    so I left 5 holes all the way around. Funny, it's about the same size as a 370 CPU. [noparse]:)[/noparse]
    So it's the RES line that I'm going to have to break out, right? About the VSS connection, shouldn't any of them
    be a good spot to hook in?
    I'm waiting for Wizard's Futurelec order to get here before I implant it into the Cyberhome player, so you
    guys might get ahead of me a bit.. [noparse]:)[/noparse]
    OBC
    <EDIT> Don't cut away too much I/O, I've got another trick up my sleeve for the Cyberhome player. :P </EDIT>
    New to the Propeller?
    Getting started with the Protoboard? - Propeller Cookbook
    Got an SD card? - PropDOS
    A Living Propeller FAQ - The Propeller Wiki
    (Got the Knowledge? Got a Moment? Add something today!)
    Post Edited (Oldbitcollector) : 2/10/2008 12:17:59 AM GMT
    I've been waiting for it to warm up a bit so I can go play in the shop! tongue.gif
    www.allsurplus.net/CNC
