protoboard eagle files ?
heres a question i thought of last night.
are there any eagle files ( board and schematic) for the parallax prop and sx protoboards ?
it would be good to have a sort of template , then you could figure out where is the best place to put your additions/ jumpers.
i am noticing that i seem to be using the protoboards as a base starting point most of the time.
lazy, i guess
dan
lazy, i guess
dan
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Paul Baker
You can write your own import/export functions if you know PADS' file format. Don't ask me how, but it can be done.
Paul Baker
Yes, but most of your customers, especially the hobbyists, I would guess, use Eagle. It would benefit both Parallax and your customers. SparkFun does something really nice with all of their products. They create an Eagle library with accurate pin spacing and labels. It is very useful.
i could do the print/layout way, but it seems more complete to do it with a schematic/board layout to make sure all the wires are right.
i have ( too many times ) just drawn up what i wanted, grabbed the soldering iron, and got to soldering.. only to find out after i had pounded my head against the wall for a couple of days, that i had the VDD and ground swapped, or sda and scl
it probaly wouldnt prevent it, but it might slow me down.
dan
Do you know the excellent free cad named Kicad, made by a french academic teacher and in public domain ?
Schematic capture, autorouter, and 3D viewer of the board !!! All free !!!
Kicad homepage (in Inglish)
http://www.lis.inpg.fr/realise_au_lis/kicad/
Olivier
Since i use EAGLE for over 15 years it should not be too difficult!
Let me know!
Saluti Joerg
No, I didn't!
I have bought the small EAGLE-version that is just enough for my small boards I do. But I always do have to bend me over making layouts.
Sounds good, I'll have a try on it.
Any experiences with it? Weak points? I wouldn't care how well the autorouter works (looking at EAGLE's router).
Nick
Never use force, just go for a bigger hammer!
The DIY Digital-Readout for mills, lathes etc.:
YADRO
A board which could stack above or below would be very useful.
