Lantronix WiPort
Hi,
I have a Lantronix WiPort Evaluation Kit, and·I was told that WiPort can send and receive data over the network wirelessly without the need to write software to it by using normal UDP programming technique.
What kind of UDP programming technique am I supposed to use? Are there any sample codes for me to test?
I'm trying to communicate with the board through serial port now.
the moment she steps into my life, things changed
I guess the WiPort operates in a simular way.
http://forums.parallax.com/showthread.php?p=686070
Just note that you cannot use the javelin programming port.
You must use I/O pins and setup Uarts for those pins.
regards peter
Here's the scenario:
I have a router installed on PC 2, and the WiPort is serially connected to PC 1 and PC 1 has got no wireless network card in it.
I tried to use the WiPort to act as a wireless card to PC 1 by unplugging the ethernet cable from PC 1 and the WiPort, but I can detect neither the WiPort nor the router of PC 2 in the available connections.
Is there anyway which I can communicate with the router on the PC 2? The router has been configured to act as an access point.
See page 36 of the userguide.
http://www.lantronix.com/pdf/WiPort_UG.pdf
You need to set IP and subnetmask, and gateway address.
If you use DHCP you need to find out which addresses are assigned,
then you can·ping the device to see if it responds.
If the gateway is set properly you should·be able to get into
the router's setup menu from any browser by
giving its IP address in the address bar.
regards peter
http://forums.parallax.com/showthread.php?p=698496
Chris Savage
Parallax Tech Support
Chris Savage
