Lantronix WiPort — Parallax Forums
Lantronix WiPort
DeliriouskidDeliriouskid Posts: 8
edited 2008-02-01 15:48 in General Discussion
I have a Lantronix WiPort Evaluation Kit, and·I was told that WiPort can send and receive data over the network wirelessly without the need to write software to it by using normal UDP programming technique.
What kind of UDP programming technique am I supposed to use? Are there any sample codes for me to test?
I'm trying to communicate with the board through serial port now.
the moment she steps into my life, things changed
  • Peter VerkaikPeter Verkaik Posts: 3,956
    edited 2008-01-31 05:49
    In this thread, the 2 last posts, someone describes how he used a Lantronix Matchport.
    I guess the WiPort operates in a simular way.
    http://forums.parallax.com/showthread.php?p=686070
    Just note that you cannot use the javelin programming port.
    You must use I/O pins and setup Uarts for those pins.
    regards peter
  • DeliriouskidDeliriouskid Posts: 8
    edited 2008-01-31 08:31
    I've managed to send data between my PC and the WiPort using UDP test tool and hyperterminal. thanks.
    Here's the scenario:
    I have a router installed on PC 2, and the WiPort is serially connected to PC 1 and PC 1 has got no wireless network card in it.
    I tried to use the WiPort to act as a wireless card to PC 1 by unplugging the ethernet cable from PC 1 and the WiPort, but I can detect neither the WiPort nor the router of PC 2 in the available connections.
    Is there anyway which I can communicate with the router on the PC 2? The router has been configured to act as an access point.
    edited 2008-01-31 09:03
    I think you need to configure the WiPort properly.
    See page 36 of the userguide.
    http://www.lantronix.com/pdf/WiPort_UG.pdf
    You need to set IP and subnetmask, and gateway address.
    If you use DHCP you need to find out which addresses are assigned,
    then you can·ping the device to see if it responds.
    If the gateway is set properly you should·be able to get into
    the router's setup menu from any browser by
    giving its IP address in the address bar.
    regards peter
    edited 2008-01-31 15:50
    Is this device being connected to a Javelin Stamp? You had another thread on this subject before and between the two it's not clear if you're using a Javelin Stamp Module.
    http://forums.parallax.com/showthread.php?p=698496
    edited 2008-02-01 01:14
    er i don't think so.
    edited 2008-02-01 01:21
    Peter Verkaik said...
    regards peter
    So it's possible to use Lantronix WiPort to act as a wireless card to my PC provided its IP, subnetmask and gateway are setted properly?
    This thread is being moved from the Javelin Forum to the Sandbox Forum.
