Soldered to uSD card adapter
I was feeling bold, so I just soldered directly to a uSD card adapter connector and ...· it works!
I pre-wetted the adapter terminals and the wire ends to minimize melting (although there was a bit of melting...).
Now, I'm thinking that what we need is a pass-through SD card read/write Windows app that sends files over the serial link...· I though I saw something (maybe PropTerminal) with a zmodem function.· But, it would be nicer to be able to do directory listings and file deletions from Windows.
This way, you can solder on a regular SD card and still access the contents from Windows...·
A lot of the MicroSD cards include a free adapter that looks like an SD card. From the picture it looks like that is what he used. If so he can just plug a MicroSD card into that adapter.
- using paper clips
- soldering adapters (as Ray did)
- using male headers w/ or w/o soldering
As the Propeller used the SPI-like MMC compatible connections only, this is generally quite simple and nearly everything works
Ray's challenge was to avoid the plastic melting when soldering to the leads
You did well Rayman.
Do I understand it correctly that only 32MB of any SD card is really addressable using the Propeller ?
That seems such a waste of a 1GB or even worse a 8GB card ?
Can somebody clarify this matter
Ron
I'm thinking of soldering a socket or pin array on so I can plug it in to various boards.
What is lacking in the world of DC card sockets is a push-push panel mount socket, often PCB does not make sense for me.
Graham
i went to molex and was looking thru thier connectors and couldnt decide on which one to order.
which would you recomend ? i like the push to release type and it would be nice to have it with right angle .1 inch pins so it could be soldered direct to the proto... i also want to use this with the sx .
if i find one that works , i would probally buy 10 or so to start, so cost is a factor.
dan
and a few other things) you can access up to 2GB (and coincidentally
they only work with up to 2GB cards anyway).
Get a pile of 2GB cards while they are cheap. Next year everything
might be 4GB or larger and these will need new software.
Paul Baker
Post Edited (Paul Baker (Parallax)) : 1/29/2008 7:06:24 PM GMT
-Parsko
You were asking about a uSD socket.
I use the surface mount socket from Sparkfun.com.
The part number is: PRT-00127 and it costs $3.95 for one, less for 10/100.
It's a push-push socket that works great.
I've had no trouble hand-soldering it to the board.
It would be easy to mount this on a tiny board with 0.1" pins to use with the proto board if that's what you want.
On my proto, I have a female header so I can plug things in when needed.
Jim
i'll have to get a few and make/buy some kind of breakout board to mount one on to do breadboarding with
dan
Paul Baker
OBC
New to the Propeller?
Getting started with the Protoboard? - Propeller Cookbook
Got an SD card? - PropDOS
A Living Propeller FAQ - The Propeller Wiki
(Got the Knowledge? Got a Moment? Add something today!)
I've done several and occasionally I have to remove a solder bridge with solder wick but it's not hard to do.
Jim
