Super Carrier problems
I have an intermittent problem with Javelin and the Super Carrier board.· Sometimes the IDE won't find the stamp and sometimes it will.· When it won't, I can unplug the dc supply from the connector and reconnect it and now the stamp is seen by the IDE.· This might take 10 or so tries, however.· How can I tell if it is something wrong with the carrier board or there is something wrong with the stamp? I'm tempted to buy another super carrier, but I have a nagging feeling that the stamp is faulty somehow.· Any thoughts out there?
Larry
Larry
Both must be stable, and VDD must be 5V.
regards peter
Larry
a latency setting. If so, set it to minimum.
regards peter
There is nothing unusual about the Super Carrier Board in relation to the Javelin Demo Board as far as programming the Javelin goes. The Super Carrier Board is very simple in its design. Peter is correct to suspect the supply and, if you have a USB to Serial Adapter, that as well. If you have another P/S, try swapping that one in a while. Also, when this is happening, is anything connected to the Javelin I/O pins?
Chris Savage
Parallax Tech Support
