Where to get a SX20 "clip" to program a SX20 that is already on a board ? — Parallax Forums
BeanBean Posts: 8,129
edited 2008-01-23 18:24 in General Discussion
I've seen these chip "clips" that allow you to make connections to a chip that is already soldered to a board.
Does anyone know where I could get one that would fit the SX20 ?
I didn't have any room for the programming pins, and now of course I need to reprogram them.
Bean.
www.iElectronicDesigns.com
    edited 2008-01-23 14:46
    Hello,
    If you can't find any of those sockets you might be able to rig something up. I've seen some special spring contact test points for sale at Mouser and some have a very thin point which should be able to contact the OSC pins of the SX20. Maybe make a small adapter to hold a pair of those to touch the OSC pins for programming and just tap off ground and the +V from anywhere else on the module that they are easier to pickup. The contacts I saw at Mouser were made by IDI.
    You could also check with ARIES as they make some odd adapters and sockets. Perhaps they have something.
    I'd like to find a ZIF socket myself that would fit the SX28 chips. That way they could be programed before soldering. If I can't find one I may just order some of the test contacts mentioned above and make one to just hit the pins I need for programming.
    Hope this helps.
    Robert
    edited 2008-01-23 16:12
    Bean,
    Is this what you are after?
    http://www.ap-products.com/home.htm
    http://www.ap-products.com/tc01.htm
    Beau Schwabe
    IC Layout Engineer
  • YendorYendor Posts: 288
    Bean,
    Emulation Technology may be another resource you can try...
    http://www.emulation.com/
    Rodney
