CUI power supplies — Parallax Forums
CUI power supplies
metron9metron9 Posts: 1,100
edited 2008-01-17 16:05 in General Discussion
What is in the little bulbuious plastic thing on the end of the wire? This is a 5V 4AMP supply, I solder 5 sets of wires to the end for my acoustic lights supply but i wonder what is in this thing. If I distroy it to find out I am not sure that I will even know what it is.
Think Inside the box first and if that doesn't work..
Re-arrange what's inside the box then...
Think outside the BOX!
    edited 2008-01-17 00:04
    It's a switching power supply. The switching is done on the mains side of the transformer at a high frequency to keep the magnetics and filter components small. That's the reason it's so compact.
    edited 2008-01-17 00:18
    The bulb you are refering to is an RF choke (sometimes called a balun), it's there to minimize high frequency noise from traveling through (in either direction). You could probably remove it but you may find your supply to have more noisie.
    Paul Baker
    Post Edited (Paul Baker (Parallax)) : 1/17/2008 12:24:33 AM GMT
    edited 2008-01-17 01:20
    LOL! I thought he meant the other end of the wire! Cripes, I feel like an idiot. blush.gif
    edited 2008-01-17 02:27
    Yeah I was wondering why you didn't answer his question, now I know you were describing the BIG piece of plastic [noparse]:)[/noparse]
    Paul Baker
  • metron9metron9 Posts: 1,100
    Since there is enough wire to connect the array of plugs without removing it, I will leave it intact.
    Thank's for the replys.
