Rfid card
Is there anyone who knows how to program RFID cards?
Can Stamp do this?
Sorry if the questions sound lame. I'm new.
thanks,
StuartX
Can Stamp do this?
thanks,
StuartX
http://www.parallax.com/Store/Accessories/Communication/tabid/161/CategoryID/37/List/0/Level/a/ProductID/114/Default.aspx?SortField=ProductName%2cProductName
Jeff T.
Thanks, I read that but I did not see anything on code for programming the card. (I could have over-looked it). But I did not see that info.
Thank you,
StuartX
- Stephen
Jeff T.
Yes, I read where they come pre-unique numbered. And I have used a couple programs to learn more about them. I was just thinking a little outside of the box where you could program information to a RFID card and have the card-reader extract that information.
But thanks for all the help. I'm still learning about RFID so I'm sure I will have more questions soon.
Thank you all,
StuartX
I suspect you may be confusing an RFID tag with a magnetic striped card. The former is generally not programmable, the latter generally is. The mag stripe card are read in a "swipe" type reader. All you need for an RFID tag is proximity (close but not touching).
Bruce Bates
I presume that the Parallax ones will also be able to be reprogrammed with access to a writer.
Although the company that markets the read/writer is a UK company, I'll supply a link anyway.
http://www.seaward.co.uk/products/Brain_Cells_Read_Write_Reader.asp
The company have renamed them as "Braincells" but they are the same RFID tags as sold on the Parallax Site
just noticed that there is a tab on the webpage for the USA group so you may be able to get further info from them?
Post Edited (skylight) : 1/14/2008 1:47:37 PM GMT
It's Only A Stupid Question If You Have Not Googled It First!!
The company that manufactures the tags we use also makes others that are programmable and some that are at a different frequency. Please see the following link for more information. As a note, our tags are not programmable. A special version of the tag would be required to be reprogrammable. Take care.
http://www.cyntag.com/RFID%20Tags.htm
Chris Savage
Parallax Tech Support
I'm going to investigate the web sites.
Again,
Many Thanks.
