Dual voltage (3.3 and 5) voltage regulator for Solderless breadboards — Parallax Forums
parts-man73parts-man73 Posts: 830
edited 2008-01-17 21:47 in Propeller 1
Here's something I've designed that would be very handy for prototyping Propeller projects on a solderless breadboard.
Since the Propeller requires 3.3 VDC and some other devices are only available as a 5 volt part. I decided to design a plug in regulator module for solderless breadboards that supplies both. It plugs into the breadboard for simple set up.
Great for the Propeller Education kit!
See it here - ucontroller.com/indexmisc.html
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
  • FrobozzFrobozz Posts: 12
    edited 2008-01-13 06:35
    Nice. I've seen a couple of these online but yours is the first to handle both 3.3 and 5.0 volts at the same time.
  • ColeyColey Posts: 1,130
    edited 2008-01-13 08:30
    Great Idea Brian!
  • parts-man73parts-man73 Posts: 830
    edited 2008-01-13 17:56
    @ Coley & Frobozz - Thank you for the positive feedback - it's something I've seen a need for, with the Propeller especially, but there are other 3.3V microcontrollers out there as well.
    wastehl said...
    Can you advise the power output of this board, I could not find it in the documentation...
    Thanks, bill
    The total maximum current between both 5 volt and 3.3 volt channels is 1 amp. But that assumes a reasonable voltage drop (7-9 VDC input is preferred) and the addition of proper heatsinks. The 3.3 volt channel has a 500 mA max. The 5 volt regulator feeds the 3.3 regulator, thus the 1 amp "total" limit.
    Should be adequate for most hobbyists.
    *** edit - these figures will be added to the documentation sometime today.
    Brian
    SD card Adapter
    edited 2008-01-15 05:18
    The documentation has been updated with schematic and specifications.
    Brian
    SD card Adapter
  • mosquito56mosquito56 Posts: 387
    edited 2008-01-17 18:55
    Bri, I would recommend moving it from misc parts to the main page. Since Misc only has 1 item. I missed it there and now get to pay double S+H but not complaining. Great service.
    Hmm, "What do you mean, it doesn't have any tubes?"
    ······· "No such thing as a dumb question" unless it's on the internet
    ········"What happens in Vegas ends up on the Internet"
    Technologically challenged individual, Please have pity.
    edited 2008-01-17 20:51
    A good suggestion, I would like people to see them. You can't sell something that no one knows you have.
    I really wanted to separate into catagories.
    • Spinstudio boards
    • Misc things (only 1 now as you pointed out, but eventually I want to add things like connectors, loose ICs and maybe PropPlugs and extra Propellers)
    • A new catagory will spring up soon, as I designed a product similar to SpinStudio for PICs, that can use some of the SpinStudio Modules
    perhaps I need to redesign the website to better showcase my wares
    Thank you for the suggestion!
    Brian
    SD card Adapter
    ·When your inventory goes over about 50 items(hopefully soon) then you will have to split them up. With only 10 items or so, I could look at everything in about 2 min. The first time I visited your site I checked the misc and thought "I can do this myself why bother" and turned off the misc page in my brain. Reading hundreds of pages a day that info took as "Useless" and I just ignored it.
    · Make sure to put a banner any time you add something as well as the forum. That's how I found the power supply when I was reading someone elses new post about it.
    Have a proping day!!
