Dual voltage (3.3 and 5) voltage regulator for Solderless breadboards
Here's something I've designed that would be very handy for prototyping Propeller projects on a solderless breadboard.
Since the Propeller requires 3.3 VDC and some other devices are only available as a 5 volt part. I decided to design a plug in regulator module for solderless breadboards that supplies both. It plugs into the breadboard for simple set up.
Great for the Propeller Education kit!
See it here - ucontroller.com/indexmisc.html
Brian
uController.com - home of SpinStudio
PropNIC - Add ethernet ability to your Propeller!
SD card Adapter
Brian
SD card Adapter
The total maximum current between both 5 volt and 3.3 volt channels is 1 amp. But that assumes a reasonable voltage drop (7-9 VDC input is preferred) and the addition of proper heatsinks. The 3.3 volt channel has a 500 mA max. The 5 volt regulator feeds the 3.3 regulator, thus the 1 amp "total" limit.
Should be adequate for most hobbyists.
*** edit - these figures will be added to the documentation sometime today.
Brian
SD card Adapter
Brian
SD card Adapter
Hmm, "What do you mean, it doesn't have any tubes?"
······· "No such thing as a dumb question" unless it's on the internet
········"What happens in Vegas ends up on the Internet"
Technologically challenged individual, Please have pity.
I really wanted to separate into catagories.
perhaps I need to redesign the website to better showcase my wares
Thank you for the suggestion!
Brian
SD card Adapter
· Make sure to put a banner any time you add something as well as the forum. That's how I found the power supply when I was reading someone elses new post about it.
Have a proping day!!
