Stange behaviour of OUTA.... — Parallax Forums
JoergJoerg Posts: 91
edited 2008-01-13 18:07 in Propeller 1
After some starting difficulties and some very helpful tips from forum members, here something i am wondering about:
If i put data on outa an am using a variable direct the result makes sense to me; if i use the variable via pointer the bits are reversed:
i.e. variable N := 13 Result direct: Bit0=1, Bit1=0, Bit2=1, Bit3=1, Bit4..7=0
Result via pointer Bit0..3=0, Bit4=1, Bit5=1, Bit6=0, bit7=1
Here a program with this behaviour:
'test2.spin
VAR byte N
    long Stack[noparse][[/noparse]10]
PUB test2
  dira[noparse][[/noparse]0..7]~~
  N := 0
  cognew(outx(@N), @Stack)
  repeat
    outa[noparse][[/noparse]7..0] := N
    waitcnt(clkfreq / 1_000_000 * 10_000 + cnt)
    N := ina[noparse][[/noparse]11..8]
PUB outx(AdrInVar)
  dira[noparse][[/noparse]23..16]~~
  repeat
    outa[noparse][[/noparse]23..16] := long[noparse][[/noparse]AdrInVar]
Does anybody know why this happens?
Saluti Joerg
    edited 2008-01-11 21:21
    It shouldn't matter, but since N is a byte variable, have you tried it with byte[noparse][[/noparse]AdrInVar]?
  • JoergJoerg Posts: 91
    edited 2008-01-11 21:43
    Yes i did!
    I have tried to change form byte to long, thats why long[noparse][[/noparse]AdrInVar] shows up in the code.
    Thank you Phil.
    Buona notte Joerg
  • deSilvadeSilva Posts: 2,967
    edited 2008-01-11 21:55
    Ths would not change anything as the Propeller is a little endian machine...
    Joerg, can it be that you are just LOOKING upside down? Pins 16..24 are at the upper side of the Prop...
    edited 2008-01-11 22:03
    Saluti Joerg,
    is it because the direction you are assigning to your LED's reads...
    ...instead of...
    [noparse][[/noparse]16..23]
    Beau Schwabe
    IC Layout Engineer
    edited 2008-01-11 22:08
    No, as he used the inverted form for
    OUTA[noparse][[/noparse]7..0] := N
    as well..
    edited 2008-01-12 05:17
    I tried the following, slightly modified version of your program (skipped reading the pins) and didn't see any bit inversion happening:
    [b]CON[/b]
      [b]_clkmode[/b] = [b]xtal[/b]1 + [b]pll[/b]16x
      [b]_xinfreq[/b] = 5_000_000
    'test2.spin
    [b]VAR[/b] [b]byte[/b] N
        [b]long[/b] Stack[noparse][[/noparse]10]
    [b]PUB[/b] [b]test[/b]2
      [b]dira[/b][noparse][[/noparse]0..7]~~
      N := 0
      [b]cognew[/b](outx(@N), @Stack)
      [b]repeat[/b]
        [b]outa[/b][noparse][[/noparse]7..0] := N
        [b]waitcnt[/b](clkfreq / 1_000_000 * 10_000 + [b]cnt[/b])
        N := 13
    [b]PUB[/b] outx(AdrInVar)
      [b]dira[/b][noparse][[/noparse]23..16]~~
      [b]repeat[/b]
        [b]outa[/b][noparse][[/noparse]23..16] := [b]long[/b][noparse][[/noparse]AdrInVar]
    edited 2008-01-12 06:40
    Joerg,
    I haven't really read this thread properly but isn't it a problem if you declare a byte variable before a long as the longs need to be word aligned. What would happen I think is that the stack would use the same address as the byte. Declare longs, then words, then bytes and you won't get any alignment problems.
    *Peter*
  • stevenmess2004stevenmess2004 Posts: 1,102
    edited 2008-01-12 10:19
    Shouldn't be. The spin compiler automatically aligns variables correctly. And long variables need to be long aligned not word aligned.
    Steven
    edited 2008-01-12 12:14
    Peter is fundamentally right; but teh compiler sorts this out outomatically in exactly that way. And it should not be a problem in the case of the posted code with just one byte only in it.
    VAR byte N
    This here will give you more issues:
    VAR byte X, Y, N
    I still suspect - as yesterday - Joerg was just looking upside down smile.gif
    Post Edited (deSilva) : 1/12/2008 12:19:23 PM GMT
    edited 2008-01-12 13:41
    And deSilva is right!
    I simply messed up P16..P23 -> PC7..PC0 and P24..P31 -> PD7..PD0
    Thanks anyway for all the tips!
    I will modify my MCU module for UMDL right now!
    Saluti Joerg
    edited 2008-01-13 15:02
    Here the new Propeller module for UMDL.
    The doc can be found here: www.systech-gmbh.ch -> UMDL -> Parallax -> P8X32A-D40
    Saluti Joerg
    804 x 644 - 16K
    804 x 644 - 24K
    edited 2008-01-13 17:16
    Joerg, do I see it right that the main difference between this board and the Parallax Proto Board is a DIN 41622 connector?
    Dear deSilva
    No! The UMDL system (formerly called HC(S)08 system) uses a simple 2x36pin header (72pol, 0.1"). This is enough for 8 8bit ports (as most other MCU's are using a port nomenclature). The MCU modules are fitting on base plate (with 10 pin headers and additional stuff). The original idea was to create a system for different MCU's (different families and different manufacturers).
    So i can change the MCU if for some reason the chosen one does not fit anymore. The system is totally modular and based on the 10 pin header philosophy. So i have developed RS232 interfaces as well as stepper motor drivers and a lot more modules (and also a lot more in mind). But this is only one part of the story: Each module (if once tested!!!!!!!!!) has the schematics ready for being used in the final design. And this is true for the software also: My EBS08 (Einfaches Betriebs System 08) is also modular, consisting on a TIC generator for controlling simple tasks and a lot of modules around. They are (at the time being) written in ASM or C for the Freescale HC(S)08 MCU's, but step by step i will write these modules for the Propeller chip.
    In fact i have realized a lot of my projects using UMDL and EBS08 for hardware and software development and i have used the basic modules to make the final design. This is a fast and secure approach and i just LOVE it.
    Saluti Joerg
    PS. If somebody is interested have a look here: www.systech-gmbh.ch -> UMDL
