POD problem — Parallax Forums
POD problem
LeonLeon Posts: 7,620
edited 2008-01-06 20:23 in Propeller 1
When I first tried POD yesterday with the POD_demo.binary program, it was OK. However, when I tried it subsequently, I got a verify error when I loaded the program, and this now happens every time. It's the same with other programs I've tried.
Any suggestions?
Leon
Amateur radio callsign: G1HSM
Suzuki SV1000S motorcycle
  • deSilvadeSilva Posts: 2,967
    edited 2008-01-05 10:40
    Empty battery? Would not be the first time....
    Does it work with F10?
  • LeonLeon Posts: 7,620
    edited 2008-01-05 10:43
    I'm running from a mains PS, and POD·puts the target program·into RAM.
    Everything works fine, otherwise. I don't have any problems loading programs via the Prop Tool. It's just loading a target program with the POD debugger that doesn't work.
    Leon
    edited 2008-01-05 10:49
    Sorry, this was unclear from your OP...
    edited 2008-01-05 13:17
    I just rebooted my laptop and that fixed the problem - very strange.
    Leon
    edited 2008-01-06 00:28
    It was your computer Leon, PCs must be able to respond quickly when a download occurs, if you are running other intensive programs or had you computer on for a long time, it's responsiveness suffers and the error you see can happen.
    Paul Baker
    edited 2008-01-06 06:56
    Thanks, Paul. I tend to leave it on for a long time. The same thing happened when I tried my desktop PC, it was OK after I rebooted.
    Leon
  • KaioKaio Posts: 287
    Leon,
    if this problem should occur again please exit PropTerminal, disconnect your PropBoard, then reconnect it again and start PropTerminal again. I have solved it with this sequence when this problem was sometimes occured by me.
    Thomas
